Learned a valubale lesson today....
Gerhard
Guys we had some real fun today here in the UAE.
We left Dubai early morning for the east coast to do some fishing in the Arabian sea.
Main target was Dorado.
And boy did they come to the party.
We first trolled and I used my Wahoo catcher from Williamson. Used the 7500 Abu on the Shimano Beast Master jigging rod and it worked like a charm. The dorrado loved it.
Ones you have a fish on the line the other angler try to get some of his friends that is following him.
My main goal today was to get a fish on the Shimano Beast Master Tiger special and Abu Brute.
I tied the cheap immatation Onda Onda on.
The Brute had braid on that my dad put on for me. He bought a lot of reels on ebay and one of them came with braid....
I used the spider hitch to make a double line and an albright to connect the 30lbs floro carbon leader to the double line.
Like Neil suggested wind the braid around the floro instead of the other way around.
Anyway we had some dorrado close to the boat and I cast the cheap onda onda out and as I start working it a Dorrie lines it up and starts to chase.
Man what a sight as that blue line streaks to the lure.
The fish connected and as I pick up the rod the line go tight and off it the fish...
The line parted at the albright knot!!!!
So I tied floro again on to the braid with the same knot and I put a white buck tail on.
On the second cast.... "INSIDE"
and
OFF.... &^%@#@ (Ag No MAN!!!!)
Same thing happens again line brake at the knot.
So I put the rod to one side and used my spinning rods. Caught a couple of small long fin tuna on the Yuziru Hidro Pencil and the fish disappeared just after 11:00
I got home put the Brute on the jigging rod and tied knots to connect the braid to the floro leader.
Then I used the rod to pull and see what happens...
The knot brakes every time at the double line connection.
I tied a double fig 8 an albright with both variances and still the knot does not hold.
I have used fire line and Tuf line XT braid in the past and connected the braid with the floro leader by just using and albright knot with no problems....
So, got on to ebay and ordered 600 yards of 20lbs Tuf line XT braid.
Lesson learned. Do not fish with braid you do not know or trust as it will cost you lures and more important some nice fish!!!!!
Know I need to find some 1 once buck tail jigs again....
jaccil
Also be careful when buying braid on ebay, I have heard there are imitations sold there as the real thing and it could cost you dearly.  Well done on the hookups and tight lines next time!
Gerhard
Thanks,
I have bought line before on ebay and never had a problem with the products I bought.
Thanks for the heads up.
neilg
Gerhard, I've had the same problem with "cheaper" braids. they either break on the knot or just behind it, always on the braid side.
Polychaete
How did the knot break, ......did the mono loop break like it was cut by the braid or did the braid slip out the mono?
I found that the softer braids make better knots and you can make as many turns around the mono as you reasonably can get away with. I try to make at least 12.
Nice to know there is still some fish to be caught there, have fun!
Gerhard
Its Dorrie season now.
At some stages there was upto 6 Dorries swiming with the one caught.
I had a strike on the Wahoo catcher and it came off. 5 meters later while reeling in the lure I was "INSIDE" again.
The only know I have not tested yesterday was the yucatan knot.
Will test it today with the braid...
Fishton
Sounds like you guys had a blast Gerhard, I am soooo jealous. Our season is coming. I have also started using the Yucatan - I like it .... a lot.
Please post some pictures of your trips Gerhard, we'd love to see them.
Thanks.
Wahoo lure by Williamson;) (what colour were you using?)
Gerhard
Thanks.
My camera is still in for repairs in SA and Fly Guy "AJ"
left his at home.
So no photos of yesterdays trip.
AJ we will have to go back to take photos.... ^^..^^..:wfish
I used the Bleeding Dorado colour.
AJ used something else.
I have no idea what the name is. I call them Pink Spinnekoppe and they were just as effective.
How awesome it is to see that Dorrie charging that lures as we are trolling and the next moment his was VAS!!!!
I could happily do this every weekend ::S
Gerhard
Fishton wrote:
That's what dreams are made of Gerhard. :)
My friend it is about the only thing I have to enjoy here in Dubai.
And the only way to get motivated for the next week. Work hard to let the time fly to get to the next weekend and maybe some fishing....
Will have to see what happens next weekend in the meantime I have a Dorrie that needs a tan on the kole.
Is lankal lus vir dorrie braai ;)
O ja,
Did I tell you guys that the temp was around 45 Celcuis when we came off the water at 12:00
Fishton
That's why you getting those great dorries! (45 degrees). What is your water temp?
My Favorite Dorrie meal -
1.Dorrie fillets cut into palm size pieces
2.Lie in olive oil/orange & mango juice with bruised(press between fingers) fresh basil leaves spread on top for 2-3 hours
3.Grill
4.Keep fingers away from teeth LOL
Gerhard
Water temp cooled down.
Was 32 C in June.
Its now 30 C and the Dorries came in with the "cooler" water.
Thanks for the cooking advice will try it later today
Gerhard
3.Grill
You were right.
Awesome eating fish.
Some of the best braai fish I have tasted!!!!
Gerhard
I think we caught around 12 Dorado's
AJ caught a nice one of about 8kg's
But there was a couple of Bulls swimming around...
neilg
Went to St Francis last night, wanted to go see if there are any yellowtail or big elf.
used BIIIG rigged artificial baits on a 12ft spinning rod with a Sedona 6000 loaded with Kingfisher casting braid.
Got 1 x lovely wind knot, had to cut off and lost 3 "artificial baits" to the rocks. Wind was pumping when I got there (no wind when I left home), packed up and went home. Wasn't prepared to sacrifice more spoons and other spinners.
Everytime I got stuck it broke on the join between braid and leader.
Seems I should have stuck with the Fireline.
neilg
In St Francis you can, right by the lighthouse.
Don't go there on a regular basis, will get one from the side one day ...
I call it EXTREME DROPSHOT.
