Yes. Ive got all braid on 2 of my reels. Penn 555 and a sealine both with braid only. I use a thicker braid (0.45mm) as topshot on top of 0.23mm backing. The 0.45 is less litely to cut your thumb if you get an overwind. Be very careful of braid it will remove your thumb if you are not careful.
Use a casting glove until you are sure that you are not going to have trouble!
