Lead melting ladle
Fly-aholic
DeonF wrote:
Hi
I'm looking for a lead pouring/melting ladle⁷
if you want to make sinkers not on an industrial scale and the pouring is in 5 or 6 ounce weights, 3-4 moulds at a time, then a canned fruit tin works well. With the thin wall thickness, the heat transfer is immediate. I have a little portable hiking gas burner and a portable plumbers torch. Leave on burner and heat tope part of lead while pouring.
Use wire at top and bottom of tin to make a handle.
I have however drilled the entry of the mould larger to 8mm to accommodate some impurities and prevent blocking due to colder lead.
kitefisher
DeonF wrote:
Hi
Hiya. Some good advice you got from Fly-aholic.
Also when you're in that area try Southport Swop shop.They often have all sorts of tools on their shelves.
Tight Lines
