eviltoy wrote:
Oh yeah you definately need a ladle with a pouring spout or groove, helps to keep the stream thinner and more accurate.
Not sure if you do this, but a trick I learnt when you mess a few up is to hold the hook with a pair of long nose pliers on the curved end, dip the not so good lead head part back into the moulten lead. It takes a few seconds to melt off, but you will always be left with a little lead on the hook and it normally closes the line tie hole. Heat it in the lead and quickly take it out and smack it on your work bench, as long as the lead is still hot enough it all comes off the hook with the shock and you can use the hook again for practising. Just wear good protective clothing and safety glasses when you do this as a few pieces will fly your way, nothing serious just like little balls of solder, but they're still damn hot.
Thanks for the info guys I think its the ladle im using. Theres no lip so its not a steady flow etc. Think I need to invest in one.
soon buddy soon (I hope).
