Landing big cats?
Tiny75
Hi,
That is actually a good question, I have not landed any monsters of 15kg plus, but have had experience with cats in the 10 to 14kg region where I managed to lip land them.  The problem is they tend to shake their heads away as your hand approach the mouth and obviously the chances of losing the fish increase with a lip land!!
You also need a fellow angler that can hold on to the rod, what if you are alone?
Lets hear what the expers has got to say.
Tiny
Unlimited
buy a bigger net...
 ive used the lip gripper with success. When he is close and u are afriad he will jerk him out of the hook, just loosen the dragg alot so if he goes he takes a bit of line... alternatively use a thick leader and tow him out...
Cheetha FS
Hey Fellas! GC will sort u out with a lipgrip aswell. As soon as the cat lifts his head out of the water i grab him with the grip. otherwise a gaff will also work but dont hook the cat in the body just by the mouth area.
nobbles
I fish alot by myself and for most of the fish now i use the above lip grip. I bring the fish in and hand line him for a little letting him tire a bit more. Than as cheetha says wait for that head to pop up and grip him. i do get impatient at times as you dont want to loose the fish, but do it slow and gentle, if you make any sudden or quick moves it will scare the fish and it will thrash.
Tiny75
Thanks Nobbles,
Thats good advise and very similar to what I currently do, only difference I use my hands, having said that, there is a big difference from landing my 10kg cats to some of the pics I have seen here, those monsters caught by enigma will take a brave man with big maranka's to lip land.
Tiny,
nobbles
Yes the gaff will hurt it. They will come to top with a bit of pressure applied, but do not bring a still green fish into shallow water and try land him. They will trash and you will loose the fish. I play my fish on a lightsh drag. So they can take line when they want, be carefull as you will nedd to judge a run from a dash to structure to break you off. If the fish is nice and tired you can bully it a bit. If you fishing with 2 poeple raise the rod tip high and than as the fish comes forward the other guy take the line with his hand with fish grip open and slowly pull the fish up. When I do this I have my hand submerged as if I get the chnace ill slide the grip or hand in there. Also, like with a landing net hand the hand In the water before the fish is close, if you just drop it in suddenly that fish will spook and that could be bye bye mr whiskers.
:::S
99% van die tyd gebruik ek my hande   ek speel die baber tot voor trek hom tot in vlak water in die donker  geen lig aan nie en sit my hand natuurlik met sommer die rubber sweis handskoene aan en sleep hom uit self as die rivier wal hoog is kan jy dit nogsteeds regkry of klim van die wal af en speel hom tot by jou  in die dag speel hom tot by jou al staan jy halflyf in die water lig hom met jou stok by jou uit die water druk jou hand wat handskoen aan het in sy mond en daar kan jy hom enige plek uithaal.
In rare gevalle sal ek n gaff in sy mond druk afpluk na onder soos n hoek en hom op n maklikker plek uithaal sonder om hom baie seer te maak.
Ek skep nooit die babers hulle is te lank en groot.
Om te weeg gebruik ek n oop seilsak dan le die hele baber in sy lengte binne en so ook kry hy nie seer nie dit hang dan aan die skaal met n hoe 3 poot staander
Baie maklik om so te doen
Hennie
Kosie
Jy sal maar n ekstra groot skepnet met n extra lang handvatsel moet kry onthou om die lyn slap te maak net voor jy hom kop eerste skep sodat die skepnet nie die lyn breek nie.
ants
Kerels,kerels,kerels...n Gaff vir n baber is HEELTEMAL onnodig!!.
Jy kan n baber met geduld laat "walk the dog" tot op die kant. Gesien hoe dit gedoen word op n karp stok met 5 pond hooflyn en n baber van 21.68kg by Rooiwalle - Vaaldam. Ek self het al snorre tot so 20 kg so geland. Geduld, beweeg agter die vis in en loop hom uit.
Ek eenkeer n groot hoek in my hand gekry toe ek in kniediep water probeer om n 15 kg baber in die bek te gryp.
Maar n gaff????
Kry dan eerder maar n groot (en sterk) skepnet.
Marthin
Ants perfect...
Jy moet net rustig met hom wees teen die kant van n dam en hy "loop" self uit.
In n rivier is dit n ander kwessie, maar mens moet maar net soos met meeste grootvis hengel voor die tyd besluit waar jy n vis gaan land...
As ek hom moet gryp, is dit duime bo en hande in daai vou onder die bek... hy gaan nerens en hang gewoonlik stiller...
Los net altyd die trace/lyn uit en hou die katrol los as hy omdraai.
Don't toss around when you target big cats.
0.60-1mm hook snoot
0.60-1mm leader or 80-140lbs braid or kevlar leader
9/0-14/0 circles and land the fish where ever you are fishing, no lip grip, garden glove and land the fish where he needs to be landed and where you want to land him not where he wants to go.
Gaff..................?? I don't even gaff 200kg sharks anymore, I tackle up to land the fish
Skuimkop
Jy het dit 100% reg en as jou jou vuis se knuckles in daai vou of soos ek dit noem 'kelkie' indruk raak die snor verseker rustiger, amper of hy in so trance in gaan. En dit is dan net jou duim wat in die snor se bek is. Ek gebruik ook ner REEF duik handskoene om daai nerf af ding te vermei en dit werk ook 'n charm. Maar ek laaik nogal om so nou en dan 'n battle scar op te doen, hahaha.
Ek persoonlik sal ook sterk 'n gaff afraai.
