kol hengel
Soutiebloem
more almal
wat sal beter werk om op n kolletjie te hengel, die lyn in clip of die lyn te merk met n permanent marker?
ek is bang om die inclip metode te gebruik daarom wil ek my lyn try merk maar werk dit net so goed?
dankie
EugeneC
Clipping up is definitely the way to go. The key is to keep your rod vertical when you've launched the cast, hold the rod with "soft hands" if you know what I mean, so when you hit the clip the combined bend of your rod and your arm dropping will cushion the shock.
DocPhil
Just as Eugene said.
Takes a bit of practice but becomes second nature.
You can also put two wraps of line in the clip to cushion the impact. Good for spodding heavier loads accurately.
Soutiebloem wrote:
more almal
dankie
I prefer this method, especially when targetting bigger fish.
I mark my lines on 3 distances in tournament ie 65, 87 and 115.
Each mark is a different colour although it is not required to be different.
The key is that you know more or less where 115m will be so you cast hard enough to get to 120, as you judge your line to be passing 100 start feathering your line (ie line touching the spool where the line is coming off) now you are slowing the line flow and the sinker is pulling the line tight.
The more you practise this the more you will get a feel for it, you can stop the line with "soft hands" as the Koki mark is pulled off, this is like a line clip method or you can let it past and when all slack is pulled out your koki mark is between the reel and 1st guide.
As Coach of various Junior and Provincial teams now and in the past I have seen how huge the difference in actual fishing distance can be on a 115m line clip. Some guys do it properly and hit out a 125m cast and cushion the clip down and are fishing between 110-115m others cast and hit the clip but the loop is never pulled out and they are fishing actual 95-105m
How do I quantify this. I as coach put a line mate on the rod and tell them to retrieve and on a peg found that 2 anglers with 115m clips were actually fishing at 93m and 110m - 17m difference and the guy on 93m was outfishing his mate 5:1.
My solution, marked both of their lines at 95m and made them fish that the koki marks, onc the policeman had settled the line was between the reel and the first guide...... They took position 1 and 2 in the zone.
Cross winds have a HUGE influence on the actual fishing distance when using a line clip.
Always double check through the day with a linemate. We get so zoned in and start looking in the wrong place for answers.
An example:
8-10am fishing is good at 110m good tempo and the kol is active.
10-12 the fishing is intense with 1 minute tempo all of a sudden the fish tempo drops to 7-9 minutes and sporadic.
My team start changing baits and dips and adding SA Powder.....
They didn't factor in a wind of 15-20km now from the side, their direction was correct, they hit the clip still.... BUT...... the bow in the line was much bigger and they were actually fishing 12m short of their kol.
Solution, even though they were hitting the clip the line wasn't pulling flat, Changed them up from M0 to M1.5 and tempo was back up to 1 minute within half an hour of fishing
Tjooona
Can someone please explain the clip process to me, do you measure out 115m on land and than clip in?
When you cast and you get to the point where the clip is hooked in, would it not result in your line returning due to the impact?
After you have casted, do you leave the line clipped in? Fish not able to run down the drag?
Bit confusing to me.
TimJan
Hi Tjoona
Yes you can measure it out on land and then clip it in on the distance you want.
when casting like was said you cast just enough to go 5m past you mark hold your rod straight up or even a bit back when you hit the clip the weight will pull your rod tip forward till it hits the water. Even on 5 lb line you will be amazed how hard you can cast and still stop it.
Then Yes you leave the clip in else with every cast you will have to measure the line again to keep your same spot.
There is a bow in your line that you bring in after your cast that should give you time when a big fish takes your bait to pick up your rod and walk forward if you are on the line clip if that does not help you can unclip and just measure your line again when done.
What i do for when max distance isn't necessary I will make a mark 10m behind my rods and cast from there. that way when you put your rod down you have 10m to play the fish with.
If ypou are scared about a big fish running you can make a mark on your line at required distance, then put a rubber band (rekkie) on the spool at the mark.
You will feel it hitting the band when casting and can stop it by hand, but if a big fish runs it will pull line underneath rubber band.
If you went past your mark with a big run, next cast just throw a bit further, reel back to your mark on line and put rubber band at right place again
