knots
Corne
What is the best knot to tie your leader to braid. I am useing a yacatan knot but it seems to slip . I also use a dubbel line in my braid. Does anyone know a better knot to use?
Yucatan to tie braid to leader is the best knot available. It becomes quite tricky though in certain types of Fluorocarbon leaders like Berkley Vanish. In the cases that the Yucatan slips, you need to double the number of turns you make around the leader... try it, and keep increasing the number of turns around the leader until it holds....
http://www.sealine.co.za/view_topic.php?id=1703&forum_id=44
Nepptune
Gt Knot can be another option...
ziggy
a very similar knot that works well for me is the Slim Beauty see this site http://www.anglers-outlet.com/slim_beauty_knot.htm This is the one I use all the time or this one http://www.marinews.com/Slim-Beauty-233.php which works well where the braid is much thinner than your leader
Corne
Really appreciate it, will give them a try! How long do you make your leaders? I usually work on about 1m. Do you think that's long anough?
ziggy
1 meter is fine provided you cast with the knot outside of the eye. I put 1 meter on and it gets shorter as i change jigs or spoons - but I never let it get close to 1/2 meter - then I replace
