Knots
Mr Zak
Good day
I know there was a topic about this before, "but can't find it"
Please can someone send me some pic in how to connect fluorocarbon to braid.
How long must your leader be, is 10lb strong enough
The braid I am using is Spiderwire 50lb.
Bigmouth
Hi Mr Zak,
The length of your leader should be 1x the length of the rod you fishing with.
The knot I use for a leader is the double figure eight knot.
Will try to find some pics and post
CarloT
I make my leader about half the length of the rod. You dont want the knot going through the eyes when you cast!
Mr Zak
That makes a bit sense as the knot will also not work lekke in the baitcaster, will 12lb line be good enough, or 10lb?
Simen
CarloT wrote:
I make my leader about half the length of the rod. You don't want the knot going through the eyes when you cast!
Don't know if the same principal applies to freshwater as to salt.
A leader is there to protect your terminal tackle, meaning should there be obstructions under water which can damage your line a leader line takes all the abuse, and so protects your thinner main line.
Also when casting that you don't put all the pressure on your (thin) mainline. You tend to break off when casting real hard with just your mainline.
The type of knot you use in many cases determines the size of the knot. As the freshwater guys use a thinner dia line their knots will obviously be smaller, and have no more effect on the guides than our bigger knots on bigger guides.
I make my leader 1x rod length + casting drop ( top guide to swivel ) and then have 2 or 3 loops on my reel. This then covers both top descriptions.
See the knot section for diffrent knots.
To connect braid to braid I will suggest in the freshwater scenario to use a UNI to UNI or FIGURE 8 to FIGURE 8.
The reason for this is I don't think you apply the same pressure to fish as we do in salt, and these will work
There are stronger like bimini to cats paw, or spider to Yucutan, bur that leaves you with a loop and as there are a lot of obstacles in the fresh I will be scared for a snag-up.
If you see your braid to braid tends to break under great pressure it is wise to double up on the line in the knot itself--meaning fold the line double when making the knot.
Any of these knots should have no effect on a baitcaster.
Simen
Mr Zak wrote:
Good day
Sorry left your question
To connect braid to fluoro ( without having a loop ) I would suggest you use the SPYKER KNOT--see the FAQ section it is explained with graphics step by step.
Just a question why will you use a leader of 10lb and a main line of 50lb. The dia of the 2 will be very different.
Check the dia of both and place them--you will probably see that you will be able to decrease your mainline dia considerably.
I would suggest to up your leader line a bit and down your mainline. the 2 in relation do not make sense.
basslover
Thanks for all the info guys...i bought some 20LB Mccoy Braid today and im going to try it with 17lb fluoro, this will be my livebait rig for catfish and bass.
Then i will use 20lb braid with 14lb fluoro for my worming rig.
Do you guys reckon this will work good??
I love the sensitivity of braid, thats why i can just think it will be awesome for worming?
Bigmouth
Hi BassLover
Is die braid op n' baitcaster of op 'n grinder?
Ek persoonlik hou nie baie van braid op 'n baitcaster nie.
Mr Zak
What will be the ideal Lb for a leader on 50lb braid, this is on a baitcaster,  Bigmouth why don't you like braid on a baitcaster?
Simen
When looking at braid as a mainline, do not look at the breaking strain thereof but more at the dia.
50lb braid (I guess ) is about ,27 to.3mm in dia. That makes it a heavy ( not thick ) braid for freshwater.
Strickly speaking your leader is always thicker than your mainline. No if you want to compare breaking strains you should go for say 55lb leader. Now this wont work as you will have Rock and Surf tackle trying to catch a carp.
OK so with braid that rule does not apply. I suggest you decrease your braid dia to .18 or .2 mm at the most. It will still be very strong but lighter and on your smaller tackle more easy to handle.
