Kinky Braid
chrisv
I recently bought Sufix Gyro Braided line (25lb, 0.26mm) but the stuff keeps on twisting back on itself and causing crow's nests. I use it on my Okuma Salina II spinning reel. Anyone experienced the same?
Chris
Simen
chrisv wrote:
I recently bought Sufix Gyro Braided line (25lb, 0.26mm) but the stuff keeps on twisting back on itself and causing crow's nests. I use it on my Okuma Salina II spinning reel. Anyone experienced the same? It is a cheap braid - that's maybe the problem.
Chris
Before we point the problem to the braid lets first see if the most important factor when spooling line to a spinning reel is adhered to.
The most crowsnests/knots/windknots are due to the spool being overfilled with line.
If you hold a straight edge (ruler) on the spool touching both the upper and lower ring of the spool, nowhere should the line come into contact with the edge.
If It does the spool is to full, or if it touches at only one place the reel might not be spooling correct and you have to adjust the spool.
chrisv
Hi Simen
Sorry, yes agree. The line is well below the max limit for the reel. i have however noticed that it is spooled more towards the back of the reel. I have today removed the spacers the see if I can get a more even wind and will report back when I have tested it.
Chris
camo shorts
When spooling, check out this link ,might also play a role in why you're having problems
http://www.youtube.com/watch?v=kwGSTZ-c4Rc
Simen
chrisv wrote:
Hi Simen
Chris
I think this can sort out the problem, remember to always spool the line on tight by using hand pressure or making sure the line is always dragging the weight.
Try it, and lets see what it does.
