Whilst we may want to put the best line possible,we dont consider that if you going to overwind, even the best line is going to weaken. weak spots are going to give sometime.
my personal view is too look at how can you look after your line, example, keep out of dire4ct sunlight (turns brittle) when storing, use of water when casting, minumising overwinds, hoe to open an over wind .
then you going to get the most out of your line.
I believe the saying that its no use have an R8000 set up and cheap line, cos you set up is then worth the weakness of the line. however i still say, concentrate on looking after the line is as important as everything else.
very seldom, does a fish break the line, by merely swimming away,
almost always you will lose a fish due to line breaking bcos of weak spots on the line, or being turned around a rock ect.
BTW i tried going as low as possible on my SL30, 15 lb line that costed me R20, and it gave me excellant results. casts very well, but like all line, once nicked its gonna give.
JUST MY 2 cents
