Kingfish in Mozambique
kobusv
Hi all,
Is there anybody who can assist me with more info wrt catching Kingfish in Mozambique? I'm going to Inhambane 20 November 2010 and want to target mainly kingfish. I was there last year and lost a Big fish (dont know what is was) with a Daiwa 4000plus Exceller and 8 ft heavy rod - i think it was too light for the fish!!! I need to know what plugs work, what time of the day, etc, etc, etc.
There is a nice reef about 400m long that you can walk on low tide.
Info would be much apreciated!!!
Thanks,
Kobus
SPIN A HOLIC
Hey there Kobus. I've done well there like most guys will tell you in the early morning and late evening. Night fishing with plugs is also a cooker.
In the day time you can still use plugs also also use leadheads if you can. Either with bucktail of the Mcarthy range. The buctails and plastics work well for the spotted pompanos and the reef fishes. Depending what the tides are will determine where you will fish and with what.
Good luck. O ja. Pink, blue and green plugs have worked well for me.
kobusv
Hi Spin a holic,
Thanks a mil for the info!!! I actually caught a 4kg yellowfin Tuna off the boat with my light tackle using a shocking yellow bucktail. I did not know that you can use those bucktails at the reefs? What size do you use?
If I use my light tackle and a big fish takes it, I will not be able to land it like last year. So I presume I need to go heavy in case a big one take the bucktail or plastic? Whats your opinion on the chisel nose plugs (red and white) and the jet poppers?
Pink, blue and green will I buy!!!
SPIN A HOLIC
Good morning.
The predator plugs are my favourite in the different colours and then the sealpoint plugs work well too.
As for fishing leadheads at sea I've found that upto 20m of water the 1/2oz to 3/4 are cookers. They are a bit small and light but you get plenty more hookups on the smaller ones.
If you are looking for a slighty heavier outfit that's still in budget but dam good I would recommend the trevalla rod. 50 to 100lbs braid rating and a spheros 8000 with 50lbs braid.
Jet poppers do work but they are mainly very popular now because of all the advertising done on them but a promise the chisel noses work just as well and cast better.
mordecai3004
why dont you give these a try
No links to other forums allowed.
Admin D
See Pic
blue42
Those are new from Pulsator and they're priced at about 60 or 70 bucks for the bigger one in the photo. Haven't tried them but they seem like the business.
Tyrone ter bruggen
Um, they're actually made by Gladiator Lures...
I have both sizes but haven't had the opportunity to fish them yet...
The quality and finish of these lures is top shelf..
And as previously mentioned, i'll post some pics of the other poppers made by Gladiator that i think should do the job...
DocPhil
Mate I was on Linene island a few years ago, never caught a king before then. We had 60 pound braid with 150 pound leaders and still got smashed a few times, you need strong strong gear or they will wipe the floor with you. In fact my second cast of the trip I hooked an estimated 40kg fish on a huge popper and he stripped ALL my line in one go. If you're fishing from the side use a Saltiga 40 or 50 on heavy surf rods, longer rods will mean better casts. From the boat you need heavy spinning gear with something like Saratoga spinning reels. Once they hit and you've got them on you need to get them in quick or they will cut you off on the reefs quick smart. And take many many poppers you will lose many. Big spoons also work well, but take lots.
Cheers and good luck you're in for one heck of a ride.
