Kei Mouth Dec/Jan
Tiger1
Will be in Morgan Bay from 27/12 to 9/1 with my Cat D Jetski.Will be launching from Kei Mouth.Anyone going to be there?
matthewswanson1
i am actually looking for a place to go to in January.
I have inquired about a place there.
maybe i will see you down there.
How long have you been fishing off a ski?
tarkabob
what was the fishing like off your jetski in kei mouth please ? I am considering getting into the sport down there ?
Tiger1
Very slow for gamefish in December when I was there.Water temp was 16.5 deg max and went down to 13.6 deg early Jan!!Bottom fishing was fine off the traditional spots.Quite a few yellowfin and dorado came out early December when the Westerlies were blowing but then the Easterlies came and brought the cold water.
tarkabob
Thanks - sorry I am an absolute novice - how difficult is the launch off a jetski out of the Kei River Mouth ? I am going down in Easter and December/Jan
Tiger1
Can be quite tricky.Best is to go to the mouth at low tide to get an idea of where the rocks are etc.You launch at the ferry and then follow the channel to the mouth....no problem for jetski's to do this at low tide but larger boats sometimes have to wait for the tide to start pushing in.At the mouth you have 2 choices,and they are dependant on the surf conditions on the day.....either go straight out through the surf but you have to be careful of some shallow rocks especially at low tide.This is not a problem for jetskis because of the shallow draft and you can generally see where they are.
The safer option is once you get through the mouth,head 45 degrees to the right and go between the land and the large bricks out to sea which break up the large waves and give you a relatively easy route to the backline which you access on the right hand(southern) side of the bricks.
Coming back is ALWAYS done on the same route around these bricks....not advisable going directly into the mouth from the backline.Be very aware of sandbanks when approaching the mouth,don't speed,just come in at a steady speed and read the water.
tarkabob
great advice thanks very much - if you are down there at all, please give me a shout on 083 4430630 . We have a house down there. Rgds, Rob Porter 083 4430630
