Probably way
tp::, but I remember this great tip from ESA a while back which is worth sharing nonetheless.
To remove rust and free ceased pliers, cutters etc, simply soak for a couple of hours in one part water mixed with one part brown vinegar...works a charm.
But careful not to soak for too long as it can cause damage. Rinse thoroughly afterwards and then silicone spray / Q20 / WD40 thereafter to keep rust free.
Back to your question Snowman, not too sure about keeping rust away other than using a spray, but as a shot in the dark....what you need to do is keep the moisture away, right?...like you do with a potjie pot when storing.... dry newspaper works better than oiling the pot... so try putting some newspaper in your plano type box (?) and if that doesn't work, try a couple of those silica gel sachets you get when you buy new shoes etc.
Just my 2 cents worth
Gilly
