Joining mono to mono with Spectra
kopstamp
Hi Guys
Since the new tutorials from enigma there has been various advances for rock and surf fisherman.
From these tutorials the following came to mind:
Can the hollowcore spectra be used to join mono to mono?
Example: You fishing in the rocks and loose 50-70m of line, but instead of stripping 140m of line you can rather just join mono back again as the "join" being very small wont impede your cast.
Kopstamp
neilg
In theory u can
U won't be able to do it free hand though (I tried), the mono is too soft and thin and so is the dacron
U need very thin hollow line
U need a hollow needle (Enigma sells them)
If your dacron is too "thick" the mono will just slide out
I bought a roll of 30lb dacron, will play some more !
Wanne use it on my spinning rods
In theory it's possible but if it's topshot and you're after big fish, my advice would be to strip the topshot and replace it (at most R60 but with cheap lines more like R25)that's worth a lot more than a lost fish.
Becomes more viable with 80lbs to 130lbs offshore rigs where line is really expensive and nice and thick, splice 80lbs with 2m of 130lbs spectra and serve off both ends and lock with spectra glue
@Neil G, I think the 100lbs Hollow Spectra is the same size or thinner than your 30lbs Dacron
neilg
Next time u send stuff to PE send me 5-10m of each breaking strain pls say that I can see and touch
Once I know what I'll use I can then order what I need
