About two weeks ago I drove over the Hartsriver below Spitskop dam. The dam was overflowing and the river was in flood. There was a lot of activity in the water but with the current so strong and the water so high fishing would be difficult and outright dangerous so I let it be. That was until Tuesday afternoon. Water levels had stabilize and the river was not in flood any more so I decided lets give it a try. After dropping of my workers I drove to the river and arrived there around 6:45. I worked my way up river to just below the dam wall. I could not believe my eyes fish was turning everywhere it was almost impossible to pick out one. It felt like Bokkoors just as I picked one another “better one “ would turn and trying to adjust I would completely miss my mark. After about 20 casts like this I was getting frustrated with myself and these fish. They didn’t seem to notice my lure. There I was making an ass of myself. With the next cast I managed to snag on some water grass I pulled the lure free and retrieved it with some grass stuck on the trebles feeling like I did I didn’t even bother to clean the hooks by hand I just hit the lure on the water the second time that lure hit the water the line went tight and it was on dad. What the heck it wasn’t very big about a kilo but at least the mombakkies was off. This was a fluke I thought so just to be sure I did it again third time that lure hit the water I went tight what would you know this one was even smaller than the first one. But it was a fish. With the nerves settled the focus went back to the turning fish. I ignored the boiling pot and look for fish rising on the edge of this frenzy as the target appeared I put my theory to test. If it is not spot on it’s a miss! That lure landed almost in the cats mouth I counted 1…2…Bam tight and the fight is on after a short hard fight I landed a cat of about 6kg. That’s better lets see if it works again next cast slightly off the mark 1..2..3..4… nothing. Again 1..2…3…4…. nothing . Next one spot on 1..2…3 tight. The theory seems right. Then I saw this volksie(Volkswagen beetle) bonnet breaking the surface I was ready the lure went straight for this volksie as it hit the water I held my breath 1…2…3….4…………Nothing. I lift my rod to start reeling, stuck! There now you have it you with your counting down your lure now you are going to loose your prize possession. You must know something about this lure, it doesn’t look like much, it is home made, I don’t know what the value in money is but it was a gift and it have not failed me yet so to me it is priceless. I started to apply a bit more pressure and as the rod started to bend the log or what ever snagged me came loose. But it didn’t come to me instead it started moving away from me at a steady pace. Ok what is happening ? the lure isn’t stuck to something solid any more,the log or whatever it was must be drifting in the current.Then it struck me, how can a log drift straight away from me when the river is flowing across from right to left ? A swimming log or the owner of the volksie bonnet only time would tell. The little 6’6 Shimano Clarus rod almost folded double and this fish just keep on taking line. I kept the pressure on and slowly it started to turn. I knew there was no way I could land this fish on the steep bank and started making my way to more level ground. After about 15 min the fish were in the shallow water blowing tiny bubbles apparently a sign that it is tiring. And then there were another sign it came up for air, I don’t know if it was the sight of this overweight boertjie or the mouth full of air but off it went again but not so far this time when I managed to turn it again. By this time it was really tired and was blowing bubbles and gulping air every now and then. When it was close enough I got hold of its lower jaw and pulled it out. Only when it was safe on dry land did I noticed I was rattling and breathing heavy. I was over the moon. As it lay there it opened its mouth and spit out two partly digested carp of about 500gr each. The scale bottomed out at 14kg so who knows maybe 1 or 2 kilos more I measured its length and it was 1,55m. What a lovely fish and what a end to a busy day! That portion of the river are going to see some more from me that’s for sure.
