Is there any such thing?
Guys
Don't crack up laughing?  But I was wondering if there's a reel (penn/trindad/sl50 and so forth like) that has a magnetic cast control like we have with our baitcaster reels when fishing for bass?
If so, who makes reels like this and perhaps model no's please?
mag-man
only the abu 6500 and the new 7000 come out with mag's, also the penn 525 mag and 535 mag in 3 differant models.
They can't put mags in a saltist/saltiga or torium/trini, cause the spools are too heavy, you would want quite a few big mag's and then would end up losing the ratchet set up.
Mickey
Hello Ryan,
I have two Penn Torque 100's with magnetic cast control. Once one has used a reel with this type of breaking system, there is no looking back. Shimano and Daiwa will have to come up with something similar or start loosing market share.
Although these reels are expensive, it is a once-off buy and you will probably be satisfied for the rest of your life. I have found what I have been searching many years and countless thousands of Rands for, and I believe that I have the best edible reels available in this country - and that is Penn!
And no Raggieman, I have had a DC20, they are not in the same class as the Penn Torque 100. The Penn has a better drag and torque and it's casting control can be adjusted on the fly whereas the DC reels is a fixed setting. The only plus on the DC is that it takes more line, but then I am not a 'Sharkieman'.
BigBass
With a little bit of ingenuity, you can mag any reel, either with fixed non-adjustable magnets (very easy) or with adjustable magnets (more difficult and requires drilling the sideplate) ...
Yes, you can even mag a Torium: :breakd:http://www.atlanticanglers.com/forum/fishing-tackle-gear/4504-adjustable-magging-torium.html
Also see:
http://www.100megspop3.com/oldvalkyry/pennmag.html
http://www.surf-masters.com/articles/devine/mag/mag.htm
http://www.charkbait.com/article/2004/Walt_Galen.htm[/b]
http://www.100megspop3.com/oldvalkyry/index.html
http://www.leevalley.com/hardware/page.aspx?c=2&p=58750&cat=3,42363,42348&ap=1
http://www.digitaldagger.com/reels/daiwa/daiwa.html
http://alamoareaanglers.homestead.com/MagGS.html
http://alamoareaanglers.homestead.com/60.html
https://www.kjmagnetics.com/products.asp?cat=10
http://homepage.ntlworld.com/christopher.macey/
http://www.torquedsolutions.com/images/toejam/Magging.pdf
http://bigtimefish.com/tackle/reelMagging/tackle.htm[/b]
These links should keep you guys busy for a while, not to mention perhaps inspiring you to mag one of your older reels! :cool:
BigBass
[color=#006600]Little Green Fish[/color] wrote:
Guys
Apart from the excellent (and pricey!) Penn Torque 100 with magnetic cast control, the Penn 525 mag and 535 mag, already mentioned, there are apparently some aftermarket mag kits (including sideplates for some Daiwa Sealines (do a Google search).
Also check out the current Okuma Magnetix range and the soon to be launched in SA Okuma Contoura range (apparently and upgrade to the Magnetix)... The bigger Okumas should have plenty line capacity, but the jury is still out on their long term durablity ...
  • 2008 OKUMA Contoura.pdf
Polychaete
The shimano Trinidad DC magnetic cast controll works very well and is full adjustable. Only problem is the price!
I am going to try and get hold of an Contura to test it.
