Hi
It depends on the shape of the spoon, the water conditions and the target specie.
Broadly speaking:
Iron Candy SV/ S-foil - a steady slow to very slow retrieve with the tip down, or at 45 degrees sometimes works, especially as the spoon comes over the lip.
Iron Candy Bullet/ foil bullet - medium to fast paced retrieve. Either as it hits the water, or else let it sink to the bottom, half way to the bottom etc. then start the retrieve. You can also wind this spoon then stop, let it sink a bit and repeat..Careful of rocks if letting it sink...
Couta Casting - Same as above with regard to letting it sink or not, but generally a fast to very fast retrieve. That said, when shad are around, I often slow the retrieve down as it approaches the lip, sometimes lifting the rod to 45 degrees and that works well too.
If the water is dirty, slow the retrieve down.
It's essential to try different retrieves and depths on the day to see what works.
You can use them off the rocks. The SV is great there as it shouldn't snag, but the bullet/couta spoon are tops too, just watch the rocks!
Good luck
