I hope there is a solution, I cannot thing of one except to put a new leader on every session or two.
Where I fish there are a lot of crabs. They are really a big problem as they keep on cutting off mono lines. It used to be only at night, no it can be anytime during the day as well.
I have found that the buggers struggle a bit with braid. So depending on where I am fishing I want to use either braid or mono lines on different spools. But every time you change a spool you do have to cut the line to fit your rig. I fish with a free running rig. So to change the spool I must cut the line to let the sinker slide onto the other line of the other spool.
Is there perhaps a clever way to not have to cut your line while changing spools?
