Infrared Reflecting lures
jaenswart
Is this just another gimmick and the latest craze to catch the angler instead of the fish? Your opinions please.
nicos
Since lower wavelenghts are absorbed quicker in water... surely infrared will not be much use?
Echo7
the longer the wavelenght the poorer the penetration.IR wavelenght is 1um to 1000um
Correct, I.R will only work well in shallow clear water because in the spectrum, red has longer wavelenghts compared to blue /green which has shorter w/l that penetrate further. The Humboldt squid aka red devil is one predator that IS able to see in I.R and it is pretty successful
Or else its a good marketing trick (again) by lure makers.
jaenswart
I know I am going off topic, but I think that one is closed. Gimmick.
I did however find this story on espn regarding UV light in lures
Opinions?
http://sports.espn.go.com/outdoors/fishing/news/story?id=4336113
jaenswart
Here's an interesting little fact about glowing lures. We've said that different colors of light travel better in water than others. Well, ultraviolet light travels in water about as well as green light does. If the sun is shining or even on a partially cloudy day, the UV rays that are hitting your arm and giving you a suntan will also travel through the water and make your lure glow under water. So even though you can't see the glow in the boat because of the bright sunlight, at 8 feet in the water, the UV rays will be causing your lure to instantly glow and add flash and contrast to your lure to help it standout and attract predators.
