Info needed on Cast Nets
I need to get a new one but need to find out how durable are the Monofillament Nets, I've also heard they sink much faster than the Nylon/Material type ones ?
Also whats a good brand of cast nets available here ?
sakkie7116
I have both types and use them quite frequently. The monofillament one i use mostly on sandy beaches where there is no rocks, and yes it does sink faster bu only slightly.
The Nylon i use where there is sometimes rocs around. Does not tear as quickly. This is however heavier than the mono nets. As for makes i cant help you. Bought my nets about 6 years ago and not one hole in it, and as i said i use them alot.
Sakkie
Sailfish
If u get a nylon net, you can soak it in linseed oil and hang it up for a day to dripdry. Makes it stronger and it sinks quite fast then.  It spreads out nice when throawn aswell. Think it is a bit more expensive than the fishing line tipe but wil last u a lifetime.
Appreciate the info, Thanks Sakkie !
Sailfish thanks for that I will definitely give the Linseed Oil trick a shot that sounds like a brilliant plan:)
