I'm new here, so I thought I'd ask for some advice
kaizer
I'm new here, so I thought I'd ask for some advice.  How is the fishing on Massingir Dam in Mozambique in July?  Any advice on what baits and tackle to use there?  I have a chance to fish there for the first time, and I've only ever fished for tigers on the Zambezi above Vic Falls.  Any and all advice will be appreciated!
Dale
Eleanor Mu;;er
Hi Dale
We are at Covane Fishing & Safari Lodge on the southern shores of Massingir, and have put your question to people who've had success fishing for Tiger on the Dam. Here are their comments:
From Tinus van Tonder: We would recommend fly fishing, meps spinners, spoons and bait – all these methods have been used with success. The trick is how, when and where. There are many things that influence fishing at different times like the climate, moon, the time of day. At the end of the day it takes a lot of patience and a bit of luck.
From Abraham de Klerk: Best spinner for Tigers in the dam-Bass killer no.3. For Tilarpia use bulli beef and earth worms and crikets. Bass you can find in the dam wall at the boat launch. Use spinners, plastic lures. Behind the dam wall you may find silver carp. Use curry carrots (small) or dough. In the gorge you will catch barbel. Use small fish, plastic lures
From Stefan Griesel: Small Double EF Zett worked the best, but change the hook from treble to single. Also small mepps spinners, size 0 or1... worked very well for the smaller tigers. We were there at the wrong time of year for the bigger fish.
From Janco Scott: The best times to catch Tigers are normally end of winter Aug-Dec when the water temperature rises and before the rains come to distort water clarity.
kaizer
Eleanor,
Thank you for the suggestions!  I don't know what EF Zett is, but the rest sounds good.  I assume that wire traces (or as we say in the US, 'leaders') are highly recommended for the tigers.
In your experience are the tigers more likely to take lures or live bait in July?
And how deep do you recommend fishing?
Dale
Ed0101
Above are the standard spinners, most anglers replace the hooks with singles and the split rings with stronger rings, attached to a wire leader of about 40lbs 12 to 15 inches long. Below is an example.
kaizer
Ed0101,
Thanks for the photos!  I'll try to find something similar here in the US before I leave for my trip.  Can you tell me the length of the spinner? And what size single hook is that?
Dale
Ed0101
Hi Kaizer, The photo is a  Effzett Twin made by DAM, in copper, size 16gr/45mm with 4/0 Mustard Big Guns hooks and Owner 50lb split rings, some guys are using larger spoons in 22gr/55mm with 5/0 hooks or even the 30gr/65mm with 6/0 hooks.
