I'm back on my counting while casting.
I know it's difficult to wrap your head around but it does work. With competition angling in freshwater it's paramount to keep your baits in the feeding zone and with night fishing to get it right cast after cast I use the counting method.
Counting from when you release the line / spool till countdown or as in my case during night comp fishing feather the line off the reel and stop it when it reaches the required distance.
I've tested this over thousands of casts, during practise sessions now I count each cast and then measure it using a line mate and the corrolation remains the same whether you use a 1oz or an 8oz.
The count must be a continuous count, counting the full number without interruption.
Try it and then you can get a good idea of how far you are casting and how far those around you are casting.
It might just also help you see if you're underestimating your cast or others are over estimating theirs and you might just see that the guy next to you is casting 20m further and therefore over a bank and getting the fish, it might look like you're casting just as far as your fishing partner but if he's catching and you're not - "COUNT HIS CAST AND ADJUST YOUS UP OR DOWN ACCORDINGLY AND I'M SURE YOU'LL START CATCHING".
With my counts on the cast I now have the following as guideline distances:
Counts Distance
16 80m
18 100m
20 120m
23 135m
26 160m
One of those massive casts on youtube 240m+ I counted 34 counts from the release to impact.
MYself with slide tackle 8oz, 13; 6-8oz HMG and a Torium 30 with 0.55mm line average 24 counts with a best ever of 26 off of Mazeppa and that resulted in a pickup that cleaned me out (Mookesh was averageing 28 counts per cast with a best of 29)
