Quite simply IGFA line must break at or below its rated line strength.
ie : a 6 kg line when tested should break at 6 kg or below.Anything above 6 kg is disqualified.
Some line manufacturers abuse the fact that the IGFA does not charge to have " Meets IGFA requirments" printed on the spool and just wack it on the label anyway regardless of its breaking strain.
The IGFA does not endorse any line manufacturer as far a I am aware.Therefore the IGFA does no testing and doesnt validate any line that says IGFA on it.
Some thing to note is as follows
IGFA tests all line and tippet samples submitted with world record claims in accordance with the metric line class designations, which vary slightly from the standard US customary designations. For example, the US customary equivalent of 4 kilograms is 8.81 pounds. Thus, line designated by the manufacturer as 8 lb class line may test up to 8.81 pounds (4 kg) to qualify for an 8 lb line class record. The US customary equivalents in pounds for metric line classes are as follows:
Using our standard kg x 2,2 = Lbs isnt the same as the way the IGFA works it out.
Metric
US Customary Equivalent
1 kg
2.20 lb
2 kg
4.40 lb
3 kg
6.61 lb
4 kg
8.81 lb
6 kg
13.22 lb
8 kg
17.63 lb
10 kg
22.04 lb
15 kg
33.06 lb
24 kg
52.91 lb
37 kg
81.57 lb
60 kg
132.27 lb
As you can see if you buy a 37KG breaking strength spool here in SA and try to claim a 80lbs line class record you are stuffed.
