Hi guys,
There are subtle differences between the original Hopkins and the Sea Iron, the edges are a lot more sharper and the spoon is slightly broader. Biggest difference would be the dimpled finishish which I believe helps with the vibrating action which is felt, especially felt when fishing with braided line. The vibration is a good indication that the lure is swimming well which normally is achieved with a slow to medium retrieve. Letting the lure "flutter" down at the end of your cast is an extremely effective method provided you have enough water depth to work with. Another method recommended for the days when the fish are wanting something different is to reverse rig the spoon ie narrow side forward , this changes the whole action of the lure to a more dartier effect. As with most spoons it is always a good idea to on a fast retrieve to try and skip the spoon on the surface, this will work well with all of the Sea Irons ( 1/2, 1, 2 ) but except the 3 ounce which will take a lot of effort as it is the heaviest of the range and is broad so it holds the water well, nice for windy days when you need to keep your spoon down. All the Sea Iron products have Dennis Swannell's spring stainless steel fittings, which I have found to be the best option for rigging the products, they are strong and keep their shape. They are a bit on the heavy side but rather that than on the lighter side. Rigging the spoon with a single hook and bucktail is a great idea, always keep a couple single hooks with bucktail spare as the elf destroy bucktail but they love it.
