I just got this Gun from a friend i have never hea
Flippie
I just got this Gun from a friend i have never heard of this gun or never seen this gun
Its says on the handle RENE CAVALERO (FRANCE)
its a 1.2m gun
Can someone give me more info on this speargun
Id just like to some info on the gun
Flippie
It does need some little work but all and all it looks very good
Flippie
On one side it says:
Rene Cavalero
Marseille
France
On the other side it says:
arbalete
Champion
Flippie
Im new to spearfishing but i free dive alot when my brother is surfing or while whe are rock and surf fishing so i know how the reefs are and so on but this is my first speargun for begining
tkei
Its an old gun but they were pretty decent in their day.
The slide ont he spear for the chord is rubish.
A few years ago I bought a rob alen rail barrel and new muzzel and put one of those handles in the barrel. A cheap way of getting a rail gun.
The muzzel you have there also not ideal.
Someone that fiddles with guns in your area may be able to modify the set up for you to make it a decent gun. A new spear is needed though.
a good back up gun,were the most common gun around. underwater world have been selling them forever.i never liked the trigger action .too much friction ,feels like you pull the nose down when you shoot.they like to snap off where the grip meets the barrel, so dont try to remove the grip. definitely fit a   new spear and maybe a rubber if neccessary.
Flippie
Thanks For the Info
Ass i said this is just a spergun for begining ill use it for lots of practice to get my aiming right and so on
But Thanks again for the info
Flippie
MOGGY
Nothing wrong with that gun.
It was the weapon of choice, for  years, untill the new generation came to SA.
When you buy a spear, for that gun, have a look, if the piece, behind the trigger notch is the same length, as the one in the gun.
Also, check the length of the spear.
If the spear is in the gun, check that it runs parrallel to the barrel.
If it bows towards the barrel, you nee to get a longer one and if it bows away, from the barrel, you need to get a shorter one.
The muzzle acts as a fulcrum and the overhang balances out the weight of the spear, behind it.
Happy hunting.
You used to get two different lengths.
I used to put a rail on mine.
Capespearo
Agree with Moggy,nothing wrong with those guns and the trigger mech is bullet proof,used one myself for years starting out.Rabitech sells loose glue on rails for around R80 a meter,that will certainly help with accuracy.Also as Tkei said,if replacing the spear get a drilled one for the spear line to be attached directly.
Good luck and welcome to a very addictive sport.
Renier Theron
I have exactly the same gun just with a rail... may be old but its bullet proof.. put a rail on she is pretty straight..
I remember the fish don't look at the gun - they more worried about the spear.
Flippie
Thanks for the info
I have a friend that stays in witsand thats exalent with spearfishing and knows the equipment very good he has all the tools im going to him this weekend and gona give the gun to him so he can fit all the goodies
thanks again
cheers
Flippie
jensent
Those Cavalero handles bring back some memories.  I echo the sentiments about the hard trigger pull.  I had a 75 that I made up myself for gallies in the kelp, and I used to really hoik the thing around trying to pull the trigger as I really pumped up the rubber on it!
I used to make up my own spears without the right tools, and goofed up the back end of it a few times.  I remember one day where my gun started misfiring, but there were fish about, so I figured out that the safety would hold it, so I shot fish by sliding the safety catch off to discharge.
And one guy I dived with (no names, no pack drill) was swimming just behind me in kelp when he had an accidental discharge.  So I swam over to him to ask what went wrong, but he had no idea, so loaded up and carried on.  5 minutes later, same thing, so I swam a bit away from him after that.  After the 3rd discharge I asked if I could have a look at his gun, and he had a snap shackle on his float line that he had clipped to his trigger guard, so every time his buoy snagged a bit of kelp, BOOM.  Clown!
::jest
jensent
::jest
MOGGY
The really old handles, used to have a thin catch, to hold the spear and whenever the spear twisted slightly, the gun would AD.
We drilled holes on the side, wher the spear went into the handle and put two thin stainless steel pins in the holes, so the spear was a really tight fit.
We made our own muzzles and I will try to find one to photograph.
I made a rail gun, by glueing two 3mm aluminium rods onto the barrel and filling it up with Eli fil, to make a rail.
The first rail guns, had the spear running inside the rail, with a litlle fin added on top of the spear, to locate the wishbone.
I still have a mould for making wishbones, out of cable.
It was a lack of money and an abundance of time, which made us devise all this sh1t.
I even built my own boat and the whole rig with brand new motors, cost me about R 13 000.
I sold it 16 years later, for R 15 000.
Flippie
Sory for asking this must sound dum but what is a muzzle and wishbone and rail barrel im afrikaans and dont understand them thanks
Eckart
Those are the best guns! I still have an old 1m that i grabbed out of my dad's garage and put a new barrel and muzzle on... I've even shot yellow tial with it... give it some TLC and it will be around forever!
:fswim
metroFail
Hey Guys
I picked one of these up for R200 at a boot sale.
is it still possible to get the rubbers or even a replacement spear without too much hassle???
im quite keen on starting out on spear fishing and R200 was very little cash for a gun.
the one i have takes 3 rubbers, a bit excessive.
thanks, any info would be greatly appreciated
