[font="Arial, Helvetica, sans-serif"]How To Temporarily Attach a Guide to a Rod[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]Content Donated by:
http://www.do-itmolds.com/[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]Editor's Note: When wrapping guides onto your rod blank, maintaining their positioning is critical. A poorly spaced or misaligned guide can severely hurt the fishing rod's performance, resulting in premature line wear, incorrect distribution of force along the blank, and stress-induced damage to the rod. At the end of the day, these factors will likelyl add up to more snapped lines and lost fish. To prevent this, it's a good idea to temporarily attach your guides to the rod once you've identified the appropriate spacing. The following steps (compliments of Flex Coat) show you how this is done.
[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]1. Heat the guide foot with a lighter.
[/font][font="Verdana, Arial, Helvetica, sans-serif"]
[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]2. Rub FLEXCOAT Guide Foot Adhesive on the guide foot, leaving a very thin coat of adhesive.[/font]
[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]3. Quickly press the guide-foot firmly in proper position on the blank. Be sure to maintain alignment.[/font]
[/font]
[font="Verdana, Arial, Helvetica, sans-serif"]If after reading this material, you have rod-building questions or comments, please feel free to e-mail Flex Coat. Flex Coat enjoys calls and e-mails, questions, and suggestions from rod builders. [/font]
[font="Verdana, Arial, Helvetica, sans-serif"]*Always wear safety goggles and follow instructions provided by the manufacturer or supplier of the tools and components you are using. TackleMaking is not responsible for any damage (personal, property, or otherwise) that results from reading, following, or referencing this article and/or performing the actions described within it.[/font]
[/font]
[/font]
