how to rig a Sabiki?
Mouldz
Ray11 wrote:
Hi guys.Please advise how you rig these things for catching bait fish.
From boat or side? No special way to rig them off a boat ,attach sinker and drop over side,from the shore you might want to attach to a float ,they are quite long so maybe cut two hooks off if used from the side
Ray11
It will be ised from the side. But how would I specifically rig it. How should it look in other words?
Mouldz
Not sure I am getting you ,these things are ready made up ,with six little hooks on short traces from the main ,with a loop at the bottom for a sinker and a swivel at top for your main line.
Ray11
Ok thanks. Was confused when you spoke about attaching the float. But it makes sense now. Thanks for the advice.
Mouldz
No probs ,they work a bomb at sea ,never tried them of the side though ,hooked a 10kg cob at sea by mistake,fortunatly about three hooks hooked into the cob so we managed to land it^^..
Ray11
If I get anything when I try it out later.I will let you know. Tight lines.
