Hooks, hooks, hooks
frank22
When the missus asks why i have so much tackle i just say , rather have it and not need it than need it and not have it.
frank22
yeah know the feeling to Eugene , i select 10 lures for a days fishing and thats it , if i catch i make a note on what lure and date , then swap out a few and then do the same over and over. so have my favourite few but just throw and see what happens.
also check what the fish are feeding on and are they on top or the bottom , colour of water and conditions also affect what lure to use.
so all my lures are in sections for the different conditions. i know i need help lol . hi my names clinton(frank <---nickname) and i am an lure-a-holic.
circa 64
Interesting thread you have going here gents, just a quick question to Frank22, I notice that on reply #17 you show an assist hook with a split ring through the loop on the hook, is this how you fit them, and how does this differ from the way that I usually do it which is to put the loop through the wire loop on the lure and then thread the hook point through the loop to form a knot.What is the benefit of doing it your way, I just copied what I saw in the tackle shops when changing hooks.
frank22
Hi Circa,
You can do it your way no problem with that. I just use either a split ring or a solid ring then attach the solid ring to the split ring and then to the lure, it just helps the assist hook to move more freely.
Oh and just makes changing the hook if you need to a little easier.
Ninja-Nic
EugeneC wrote:
Anyone try Katana hooks on lures? They're supposed to get superior hook holds and less throat hooking.
Supposed to be super sharp hooks. They look a lot like the Mustad Catfish hooks (right)
EugeneC
You are quite right there Ninja...I have not tried them on lures, I'm not sure about the shape, being that it's not inline and all. I tried them in the surf a couple of times and blanked solid, so I can confirm they don't have special fish attracting properties. ;)
frank22
have not used them either , i have used owner ssw those are not inline hooks found them to be a bit harsh on the side of the fishes face.
hey Eugene what is the weather like in Oman in may.
EugeneC
May is a little unpredictable mate. It's close to "khareef" season, which is basically a mild monsoon. I wouldn't come later than April if I was you, fishing deteriorates after April and only picks up again from September.
frank22
aaaaarrrgggghhhh no man , i can only get leave end of may. the missus and i wanted to do a trip to oman , we been to dubai and alot of people we met there said we should go to oman. oh well maybe see in october or november take some unpaid leave.
EugeneC
Sorry to spoil your plans mate, but I can't lie, May is dodgy weather wise. Last year there was even a cyclone around the musandam area and if I'm not mistaken that was also in May. Fishing's pretty good in November if you can make it then.
