Honda 90 problem
debronski
Hi
I have a problem with one of my Honda 90 fourstroke motors getting water contamination in the oil, if i run it on the trailer with ear muffs all is fine, as soon as i launce and run her for a short period (20 minutes) get water into the oil the oil level increase with at least 500ml, to date I had the Head Gasket checked and replaced, replaced the power head gasket, checked the thermostat but the problem does not go away, does anybody have any suggestions please.
naks
did you replace the impeller?if you did then the seal in the housing must be damaged.happend on my 100 four stroke.yamaha.
