Home Made wild bird feeder!!!!
This is a homemade bird feeder made from 2 x plastic 1 liter coke bottles, This one is installed right in front om my bedroom window. The joy these little feathered friends can bring early in the morning as the converge on the feeder is a good way to start your day,,,, Please note that once installed it will take about a week to ten days before they take note of this bonanza,,,, Another tip is to install it on top off a concrete floor as they tend to spill a lot,,,this seed spilling is then eaten by doves and kwiksterkies who for some reason or other do not eat from the feeder. I have to refill this feeder once a week !!!!!!!!!so popular it is with my feathered friends!!!!!!Should any one be interested in building one,,, feel free to ask,,, its really very easy at vertually no cost...
Maestro
Thats awsome..charity & kindness are not confined to fellow human beings, but extend to animals as well,and if others are encouraged by you to do the same,then you also aquire a share in the good that they do..great gesture..i'v tried conventional and fancy bird feeders,but the birds don't come near them...a simple round plate on a cement floor is where they flock to feed! Really interested to get details on the 1 that you'v made..mayb you can pm me the details on how to go about it?
zulu-X-treme
Gee's I hope my wife doesn't see this... ^^.. I'm only kidding... ::rofl: Please send me a 'PM' as well Gerhard, cheers for sharing your idea... vvidevb
Mangi
"Our Humanity is measured by how we Treat Animals" Mahatma Gandhi
Good on you Chock. Have some mana.
Thanks for theQuote Ouboet Mangi!!!!!!!!!!!   I,m sure my woman-0-matic will treat me beter in future!!!!!!! cant wait for her to finnish washing my scoot,,,,,,,,then I can rub this quote under her nose!!!!!!!!!!
D.I.Y bird feeder, take 2 x plastic cooldrink bottels,,, wash them out,, I have found that a 1 liter bottle is the perfect size for the seed container
for the feeder nozle I make use of a 500ml plastic cooldrind bottle,, see the section that is painted black,, that is the section that is going to be bend upwards so as to act as a stopper for the seed,,, note that the blade shows the approximate depth that you have to cut into the wall (marked xxx), The plack painte section is exactly half of the bottle!!!!!!
See the black painted section being bend upwords and fitted into those cut (XXX) slides you have just made, that acts as the seed stopper!!!!!!
The cross on the  1 liter main seed storage bottle is where you are going to cut two slids the size of the diameter of the bottle neck entrance,, about 20mm...
force the feeder noze into the cross slid you have just cut and Bobs Your uncle there is your feeder,, all that remains is to take some clear silicon and seal the joint between the two bottles and the stopper lip.. I have found that the best results is to fix the feeder to a small planki (put a big blop off clear silicon at the bottom of the 1 liter bottle and place it on a planki gving it time to dry)which you then fix at any which way where you want it,, At first I tried hanging the bottle but I found that the movement (wind and birds) when hung is to much causing to much spillage!!!!Having it fixed to something is the solution. This is also a totally waterproof Feeder,, remember to give the birds up to 10 days time,, it does not matter where you place it they will find it!!!!!!!!once the silicon is set you can remove the excess plasti on the seed stopper. Once the birds is used to the feeder you cam wrapp the bottle in a thick grass using elastic bands to keep the grass thightly wrapped around the bottle,,, it does make the feeder look very natural,,, I,m stiil to wrap my feeder,,, maybe woman-0-matic will catch the hint!!!!!
I see you stay in Richardsbay Ouboet,, About 4 years ago I did a job in Hslusuwe (Spelling)  a game lodge there,,, I had a tame meerkat who was more tame than your smaal skoot hond,,, I ran over it with my boat,,, I was so devasted,, The owners gave me permission to make a small grave, inclusive of a cross,, in a dedicated piece of ground as you enter the property,,, one day I,m going to vist my smal friend on the lodge!!!!!!!!!
Was taking a afternoon nap and along comes two feathered (Mossi) friends to feed,
This is what happened next,, I would pressume one was a youngster and the other a parent,,, The youngster would sit on the burglar bar and Mama would jump between the feeder and the youngster and feed him one seed at a time,, every now and then the youngster would get brave and jump to the feeder himself,,, with a big noise and wing flapping Mama would chase him right back to the burglar bar and promply proceed to feed him one seed at a time,, this went on for a good ten minutes,,, what happened here???? the seed micture I have inside the feeder is commercial wild bird seed bought in your local supermarket,,,, is it perhaps that the youngster is not allowed to eat everything in the feeder or was she teaching him something???
Fredster
kewl, good on you. i have some seed, i think i'll use a energade concentrate bottle which has a bigger opening at the top - should be easier to refill. We feed the birds bread in the middle of the lawn so our cats don't have too much cover to get close to them, otherwise it feels like i'm baiting them for our cats and not just feeding them...
Anu which way,, the tipe of bottle You use Ouboet Fredster,,, the main advantage is the seed stays dry in the worst of weather,,,  and its an extremely sturdy setup and you can raise it to a hight where the cats cant easely reach them...
