Hlep : Saltiga part dimensions
methus
hi guys ... i need some assistance. where can i find the dimensions for the part below. lost mine !!!
it's the o-ring the fits on the drive shaft of the satiga surf 30.
based in CT and ordered one via the local store ...KF sent the wrong o-ring with correct part number. anyway decided to source one locally from an o-ring supplier. i need the dimensions though. where could i locate this ?
Key Number : 47
Part Number : F65-7801
Part Name : O RING A
thanks
FRITZABU
What o ring did they send ?
Its a very small o ring . Should not effect your reel in any way .
May even be the same size that was used on the grand wave series of reels .
Psy
:::S
I have the same issue, but refitted the reel without the O ring. I dont believe it to be a train smash. (was hard and brittle when removed)
Source the O ring from an engineering supplier. You will have to have the shaft in hand though.
BR
methus
hi guys ... you are right. the o ring fits on the shaft and prevents water getting to the drag stack ...really an issue if wading. i am using the reel as is but it bother me knowing it's not there
i will strip the reel and take the shaft with me in search of a replacement.
thanks guys !!!!
