Sensations new Whiska catfish rod are very nice and similar to the Ugly sticks. Available in 8 and 9 foot. I have used both lengths and am very happy with them.
Very well priced as well.
I use a small boat to drop my baits as I believe in big baits for barbel so do not cast with them.
Mine are paired with Alvey 6500 reels and this works for me with the way I like to set up my rods on the bank. I use the Alvey that only has a spool tensioner and no drag with the handles mounted directly on the spool. This way I can lock down, without having the drag slip if I need to stop a big cat from getting into structure or if I am fighting the cat from the boat I can put maximum pressure to lift him of the bottom.
These rods can also be used with big coffee grinders if preferred.
I don't like using multipliers for big cats as it is much more comfortable having the reel on the bottom of the rod.
They have a reasonably soft tip which is great while the cat is mouthing and swallowing the bait and then bends away which effectively shortens the rod when the fight starts allowing you to put some serious pressure on when needed.
They are very tough rods.
They work for me and the way I fish for cats, but I suppose as with all things each person has his own preference.
So depending on how you fish and what your requirements are you want to also have a look at these rods.
Tight lines.
