hi kan iemand my se of die docs camo lyn goed is o
Schalkgrobler
ek hengel met docks camo lyn baie goed ek moet se was eers skepties daar oor ek het altyd double x lyn gebruik. ek het 4kg docs lyn met 8kg suffix leader wame ek hengel. stel voor jy kry n toll en probeer self
wmpruis
Definitief Double X, het al met ander lyne gevang en Double X breek nie so maklik soos die ander gemors nie.
Trophy
Hiya Guys,
Like Mark said...have a look at the Awa Shima lines. A number of Champion Anglers cant be wrong? There are a number of lines in the range, each with their own qualities.
PI
I tried the Awa Shima line and was very impressed, however I might have gotten a bad batch the 2nd and 3rd time, so I switched back to XX.
Will definitely try it again soon.
PI
Naruto
Double X has a new line that is Hi-Viz(orange I think) and a black Hi-Abrasion. Both are excellent and i have gotten twice the amount of use out of them than any other line I have tried. I use 0.17mm (5lbs) and my casting has improved too.
wmpruis
Daai hengelaars was met daardie lyn gesponser. As hulle deur doubleX gesponser was, was die prentjie anders.
