Hi guys> we are going up to mozambique chidengu
junglefisherman
Hi guys> we are going up to mozambique chidenguele in november and are going to do lots of rock and surf and would also like to do some drop shot fishing.
Does anyone have some advice for us.
Stapies
I have not had the pleasure/privilege of going into Mozambique, but I have gone as high up as kosi bay... There is many lures that will work for Mozambique and I have also seen many a fishing videos and reports for there. I have fished Mauritius on artlure and man what an experience that was!!!
I think the following is essential to take with, A variety of dropshots(different sizes and types...), surface plugs(chisel nose, pencil nose/GT Ice cream), Poppers, spoons, bucktail jigs and rappalas if you are taking a boat with...
One thing to remember is to take some light steel if targeting the boys with tooth as these game fish can become very expensive if taking lures of... The reefs are very often full of triger fish, They destroy soft dropshots very quick and then it is best to go for poppers/plugs or bucktail and spoons.
The GT's love the surface lures and I think it is every mans dream to land one. They are dirty fighters so use a leader and make sure your tackle is strong enough for what you are targeting. Will you be going on a boat as well?
I have seen many small kingfish species come out of the beaches and that is on everything from spoons to dropshots!!! The iron Candy is quite a killer and I normally take a few spoons with when going to "warm water" places and always try and match the colour and size of the baitfish in the water... And match the baitfish with the dropshots as well...
Post a report on the return and I hope someone can give you more specific info...
junglefisherman
Thanks for the info much appreciated. Looks like i'll be making some tackle shop owner a happy man with the shopping list. will definately give feed back on the trip once we return.
Stapies
Also have a look at these pics, these guys were nice enough to take pics with the lures in the fishes mouths... But many other lures also works great!!!
http://www.sealine.co.za/view_topic.php?id=77033&forum_id=1
popper 1
Howzit guys,
I'll be happy to assist where possible and with what has worked well for me.Dropshot is probably one of the most productive ways of fishing in Moz.I have been chucking plastics for the past 6 years in Mozambique and it's been one helluva ride.There are 2 different ways of dropshot-heavy and light.The best set-up for light dropshot would be a 7'M - Medium Heavy outfit with 10-15lb braid (look for .16 - .19mm diameter.I like using the Power pro Super 8 Slick because of the castability,but there are other great braids on the market.Couple that with a 20lb - 25lb fluoro leader and you're set.I've been connecting the 2 with a 35turn Bimini on the braid and a 5turn surgeons to the leader.Very strong connection that i've been trusting for years.Best sizes are 1/4oz nitro jigheads with 3inch minnows for wave garrick and small kingies in the surf.Rule of thumb,the more bright and clear the conditions,the more translucent and erratic you go.Next and the most favoured is 1/2 oz nitro jigheads coupled with 5inch minnows.Always try and use jerk shads with the split tail.Paddle tails tend to foul as the primary retrieve is with speed.There are two types of retrieves that have worked well for me.The fast,erratic retrieve immitating a fleeing baitfish and secondly the wounded baitfish.The first one is done by holding the rod horizontal with the tip pointing to a backhand tennis position.Then you give the rod fast jerks while winding with speed.It takes a while to get into the rythm,but it is technique specific.As soon as you can impart the darting side-to-side movement onto the lure,you'll be getting hits.The second is holding the rod upright,winding down and flicking it back up, imitating a fluttering,wounded baitfish.The Pearl Watermellon is by far the best to use in general.Chartruese works well too.Look for turbulent,white water with current and structure over a pushing tide.Don't be scared of fishing in the wash,that's where kingies love to hunt.
Next is the heavy shore-based set-up.Look for a 9'-10' XH rod,a good spinning reel in the 5000 - 6000 class,with 20-30lb braid,depending on diameter.Look for .28 - .30mm diameter.With a 9' rod use a 2oz Nitro jighead with a 7inch minnow.There you use a slow bouncing on the bottom retieve.Hold the rod high and without stopping your reelwind,drop your tip and jerk it back up.The idea is for the lure to bounce close to the bottom.Bigger kingies go nuts for that.We've caught Gt's of up to 26kg with that set-up.Depending on the prevailing structure,you'll be able to land bigger.Go with a tight drag or you're going to get smashed.Good reel is vital.Look for turbulent white water over spring tides if possible.You need current,structure and baitfish to catch Gt's and they go nuts for dropshot.Colours that have worked well for me in the past is Blue Pepper Neon,Chartreuse Pepper Neon.Retrieve is more important.
Should you be going on a boat,you'll catch even more fish.Fishing over shallow reefs,you'll be caining fish.Biggest key is retrieve with SPEED!.You're welcome to give me call on 0824960564 if I can assist in any way.
Let us know how it went.
Popper
junglefisherman
Howzit Popper1
Thanks for all the info. I am really looking forward to the trip. Which area's in moz have you fished we are going to chidenguele.
Will give feed back once we home.
