I've tried several Permutations , none Of them as Neat Or well though out as the glowstick in the Skirt storythough .
Nevertheless- I use glowsticks for Non-eds rather than try foreds, though i cannot specifically tell you why . I have seen the Chokka Bomb With Glowstick Inside it , and Withing Minutes Of Danie Putting it out , he got an ON and it Was a smooth hound .
I had 3 Pick-ups One Evening , after Frans the ray destroyed The Stroke 7 at saal.
We'd been standing there and nobody was getting anything .
I hit upon the idea , and Within 20 Minutes of putting the Macekral On under the Green Light given off by the Stick , i had a GOOD on . Every now and then i remove it , as i am Not spcifically convinced that Non Eds can either actually SEE the colour , Or whtehr they respond differently to the light .
I Would flip the skirt The Other Way around - it Makes the skirt Flare , if you Will , and Gives the trace more movement .
