Hi guys, The bank manager eventually
Skaap Tjop
Hi guys,
The bank manager eventually decided that my budget don’t allow a Saltist 50 and 30, so I got the sl30sh
Can anyone please give me advice on what will be the best rod for targeting smaller edibles with the sl30sh?
I'm thinking of the Exage 10ft or the Beachmaster lite...
Any suggestions????
S-T
scorpion
blue marlin 12ft, or western accessories has a 4 piece 12ft hmg for about R1000, throws 4oz and 50z very nice rod excellent for throwing plugs as well
G
Guest
Guest
Hello Skaaptjop, ek raak sommer lus vir braai!
I bought a Daiwa X-30SHV and an Exage 11' rod a couple of months ago. What a combination!!! I was so impressed after my first use that I went straight back and bought another 30SHV reel to put on my 350/2. These are now the only kit that I fish with. The bigger guns have been hibernated and only get taken out of there sleep if I feel like putting out some live bait.
I would sugest that you get the 11' exage. You can easily cast in excess of 120 mt with a 2 oz sinker and over 150mt with a 3 oz sinker. What a pleasure, what a combination! I just love my 'baby' and would go nowhere without her.
Skaapie... I agree with Mickey... if you want the best of the best... then you have to go with the Shimano Exage Surf 100 or 110. (10ft or 11ft). They are HMG rods with Fuji guides and, get this: the 10ft is rated to through 7 (SEVEN) oz (200g) and the 11ft is rated to throw 9 (yes, NINE) oz (250g).
Once you got this rod, then you can eventually save up for the Saltist/Saltiga 30, which would then, in my opinion, be the ultimate light tackle rig - capable of casting miles... light enough for anything and strong enough to pull too.
Orchinis
Hi the SL30 is a little reel with a big heart, I know of a few anglers who sold them and later regreted it. I've got a 13'6 ft Kingfisher Stimulator (the new models now come with Fuji guides) to go with mine - a perfect match! easily handled a 10kg Black tip and a Duckbill ray of similar size! countless Shad, Blacktail etc as well.
I'm using 400m .37 Siglon with .60 Maxima leader (works realy well 4 me:D)
G
Guest
Guest
Hello Orchinis,
Be nice, go to 'My Account' and put in your location. It is nice to see where the guys are from.
I use .40mm Perlon (14.40kg) line with my 350/2 and .30mm Perlon (8.80kg) line with my Exage 110. I use Perlon .55mm (22 kg) line for a leader.
Skaap Tjop
Thanks for the advice guys,
I was leaning towards the beachmaster light, but sounds to me like I must go with the Exage, so Exage 110 it is...
Appreciated, thanks.
G
Guest
Guest
Good choice Boet. Wish you were closer so that I could let you use mine to whet your appetite. Now if you really want to put some distance on that reel, think about trying .30 mm Perlon line. At over 8kg breaking strain it can handle most of the edibles and because it is a 'hard' line', it just peels off that reel. You won't believe the feeling of satisfaction that it will give you when casting.
Although the rod is rated for far heavier sinkers, you will find that you get the most enjoyment using a 2 and 3 oz sinker and will only go heavier if the conditions dictate it. I also find that by using a light sinker and light tackle I am outfishing all my pals by far with my Exage. They go home empty, I nearly always go home with something edible. Winter fishing asks for lighter tackle and this is in my opinion the closest to the perfect winter tackle that you can get.
Keep in mind when throwing the light sinkers to give it 'air', i.e release earlier than you are used to. I say throw, because with this tackle you do not 'cast', you can swing that combination with total disrespect and force and it will not let you down.
Razeen
I agree these reels are gr8.
I have the grandwave z 30 and the x 30. Shimano 3 piece 14ft 1446 and a blue marlin t53 stroke 6
You get good distance with these reels because the spools are smaller and the line has to travel less when coming off
Pylstert
 I agree, you can not go wrong with a exage 110h. It is a butt kicker of a rod. I think the casting weight is grossly over egagerated though, but it will handle a 5 ounce sinker. I often use it with my sl50 with .43mm line and it handles that no problem. But 6 ounce is too much for it. There is a new 12ft Shimano rod on the market with an unpronounceable name. That thing will cast a 12 ounce sinker no problem and it is extremely light and thin. Mia's in Woodmead had a couple in stock, but they cost. They also use new Fuji eye technology.
You won't make a mistake with the Exage 110h it casts like a dream.
Leon
G
Guest
Guest
I agree with you leonj. The sinker rating for the 110 exage is overated. I can get my rod to 'snap' with a 4 oz sinker, but it 'snaps' (breaks) best with a 3 oz. If you use a heavier sinker, I am sure that the rod will handle it, but you cannot expect to get a reasonable distance.
Ya I get what you're saying about casting weight guys, but I think you're missing the point. While casting weight rating of 250g is massive, no-one is really going to throw 9oz with an 11ft rod! :crazy1  - it's more a reference to it's strength than anything else. A rod with a 250g rating printed on the side has GOT to have some serious pulling power and strength... which is fantastic to know once you've hooked into something reasonable. Surely it is much better with lower weights casting... I tried a 5oz and it's just not balanced at all. But it bends into a 10kg fish beautifully on light tackle!
Just my 2c.
G
Guest
Guest
Your 2c is worth a Pound. You have hit the nail on the head. Never thought of it that way before.
Harry
Hey Guys/ Skaap
Good choice on the reel. I'm a die-hard Daiwa man. My wifes gona kick me out one of these days. I got 2 sl20sh's, sl30sh, sl30shv, 4 sl50sh's. (Call it a craz if you will):dban:
Listen, if you looking for a perfect match for it i suggest you choose sumting not too light. I personally use a loomis two piece, 13Ft but i prefer using my purglass 400/3 with my sl30shv :cool:. Man-o-man You should feel this rig, match made in heaven. The rod is light enough and strrrong enough to target any light to most heavy fish. now the important stuff.....
When you choose a rig(a rod for a reel) it is important that the rod is stiff enough to allow you minimum flex when throwing and flexible enough to allow you to reel in your catch. Sounds craze i know. I find my 400/3, 14ft 6 does this beatuifully. You  should see me spoon on this rig...:first
