setobla wrote:
what casting tecnique are you using. when i practice on a field i easily get 200m but when at the beach or on the rocks i barely get to 120-150m max.
First of all casting at higher altitude helps a lot so you have to remember that if you practice inland.
Secondly your footing and / or the Arc of your sinker is just about always compromised so the cast will never match casting from flat, firm ground with no obstructions.
@Armand, brilliant casting and really pushing that rod to the max. Pity it flexes so much low down, that's probably costing you a couple metres.
