Hi Guys, I know that fish ,like us ,don't alway
Tigerking
Hi Guys,
I know that fish ,like us ,don't always have the need to eat.Their appetite is mostly controlled by Barometric pressure sometimes. The question is when exactly is the best time. Some say just before a cold front and two days after etc...And what pressures  are we looking at??
RedEye
Trophy wrote:
HIya TigerKing,
Welcome to Sealine!
Our PE numbers are growing...soon we will rule the world!
You okes have too much time on your hands. Productivity must be really slow in PE!
This is the short story.
Barometric pressure is like a sodastream machine. You need to keep the bottle / water under pressure before the water will absorb the gas. If you pump the gas into the bottle without "pressurising" it, it will absorb nothing. Same effect with the ocean. The higher the pressure the more water absorbs oxygen. If oxygen levels are low, fish will be lethargic and not eat. Just like you and me, when they haven't eaten for a while and suddenly they get an appetite, they go into a feeding frenzy. Hence the change of weather, change of feeding patterns. Cold front's have nothing to do with it but probably has more to do with the wind which a) increases the pressure and b) messes up the surface of the water allowing it to absorb oxygen. We generally have consistent weather patterns, high pressure cells and low pressure cells developing in the same areas because of fixed land / sea conditions. There fore we associate the "cold front" with "fish coming on the bite" but it probably has more to do with the wind over surface and wind direction. If the wind is pumping, conditions will change and the pressure will rise. You will also notice that guys talk about fish coming on the bite when the wind changes. It has nothing to do with it but rather when that wind changes to NE, the barometric pressure has risen. Then the NE (in Durban) messes up the surface combined with the high pressure, oxygen levels are at their highest.
Specifics on barometric pressure has been nicely laid out by Fanie in his post.
Just my 2c
Tight lines
adam5016
Just my 2c
Tight lines
and here we were only looking for "before or after cold front."
shot bennie. that not worth 2c - at least a R10
Maasbanker
Just my 2c
Tight lines
I'll give Bennie a R10 also for that rather practical explanation !! ::tclaph ::tclaph;) Easy to understand and spot on !!! Thanks Bennie !
Tigerking
Right on! I never use barometric pressure to determine if I 'm gonna go fish. I Monitor the weather patterns two days prior and know then wihch spot works after the specified weather because in the change of the water conditions, colour temperature etc. On top of that I use seasons and feeding patterns from past experience. If you start thinking like a fish you've got half the job done already.I just check the barometer to see if I need to pack in my Drimac or prepare for more wind . It all goes hand in hand and is actualy a science. People who say it's luck don't have skills.
BigBen
Makes perfect sense. Like yesterday on the Falsebay coast. Beautiful color water but no wind...Sea was flat = NO FISH. no oxygen in water.
However today the wind picks up ruflles the surface and the fish will be back hungry as ever.
TIGHT LINES EVERY ON AND A BLESSED CHRISTMAS TO ALL.
Now I'm officially on leave.
BigBen
Maasbanker wrote:
Stywe Lyne BIG BEN and may you be STREEEEECHED before the New Year !!
THX same to you.
I have the perfect wife who actually permits me to go fish this afternoon while they do the hair thing for Christmas today. Lekker nê.
:wfish
Fanie
Good explanation there Bennie ! Never thought of it as a soda machine ;-)
Best fishing I did was in the rain and when the wind is up.
adam5016
Went fishing last night in near perfect conditions. The pressure dropped like my brandy later last night - not even a nibble. seriously not even barbel.
Fanie
Fish is actually a good barometer. Like you say Adam, when they go off the bite, expect something.
Last time when I realised there is something up I was on Bloemhof between the islands. When I looked up it was like a big black curtain with hell in it. The trip back wasn't nice. I took the short route back - 2m swells, short and furious, almost dislocated half my joints.
