Hi Guys How about putting your favorite combo f
YzeOne
Tell me how right or wrong am I with the following combo :
Rod : Daiwa Exeller
Reel : Daiwa BG20
Line : 12lb Berkely Fireline with 40cm 24 lb Flourocarbon leader
duckbill
i use this combo when spinning/dropshot for small leries:
rod: elbe 6ft6 dropshot/spinning (medium action)
reel: shimano grinder (2500)
line: 3.6 kg kingfisher
lures: mustad and kingfished
Jacquesdw
Out of the only two I have my favorite is:
7' Sensation Passion Stick ML (1/8 to 1/2 oz)
Diawa Exceller 3000
15lbs Mustard Ultra Braid
Maxima FC leader either 12 or 20 lbs
Marshie
  • Fenwick 7ft HMG medium / heavy[/*]
  • Daiwa Tierra 2500, Suffix 20lb
Now if I could just win the lotto I would upgrade the Daiwa to a Stella 4000.
G
Guest
Guest
Current Set up:
  • Rod: TFO 7ft Heavy Action 3 piece spinning rod[/*]
  • Reel: Shimano Sustain 4000 Fe[/*]
  • Line Fireline Crystal 10Lbs
Ultimate:
  • G. Loomis 7Ft Medium Heavy[/*]
  • Shimano Stella 4000Fd[/*]
  • Fireline[/*]
Andz
I have shimano 8'6" "charter" fast action graphite rod
was very happy wit the results this past week
i think i had the biggest rod of the dropshotters that where there with me, but nothing went past wit out me feeling it
& shimano sidestab 4000re CGrinder
loaded with berkley 10lb fireline wit +- 3m of 25lb Maxima floro carbon leader
& lotsa berkley lures.....
btw i have the little berkley buckets & 2 of them dont seem to be closing properly...any of u guys have the same problem
WaterHond
Hi Baardman,
I got the 8' Sensation Passion Stick, with diawa exceller 3500E and 20lb braid and 50lb fluoro.
What length leader do you use, that last eye looks very small... Do you have trouble when casting?
YzeOne
When I bought my kit , I asked the same question  & the salesman said that a 400mm/40cm leader was sufficient. So that's what I use. I just make sure that the double uni knot joining the fireline to the flouro leader is outside the eyes before casting.I have not had any problems since. my 2c !
willo
i enjoy the exceller 8ft rod and the 2500 exceller reel with heavier of the to spools filled with 10lb suffix braid(275m) and 12lb maxima fluoro leader,fantastic alrounder
on the other spool for the skiddish fish 4lb vanish,4lb crystal f-line and back 4lb vannish fluoro with the same rod. (not sure if berkley vanish has hit the selfs there yet,its about R130 for 250yd in oz,where maxima fluoro was about R45 for 50yd)iv been fishing it resonible hard-hasn't failed yet
ignoblis
I have been using the Vanish Fluoro ( in SA)for over a year now but find that it doesn't tie as well as other FCs
ignoblis
DropShot76
Light outfit:
Shimano Nexave 6'6", Daiwa regal 2500, 10lb braid
Heavier Outfir: 8'0" Passion Stick, Diawa Exceller 3500E, 19 LB braid
