Hi Everybody This social isn't just for the gen
Hooch
[color=#006600]Doubledeadly[/color] wrote:
Hi all,
I just want to thank everyone for your hospitality.  It was nice meeting the "guys".  Please contact us for all you requirements.
Regards,
Marius
Hi Marius,
Nie seker of ek jou gegroet het Saterdag nie, maar wil net dankie se vir die "Bleeding Wire" en die saltist se bearings wat jy vir my gestuur het. Daai bearing spin teen die spoed van wit Bollie, as jy vertaan wat ek bedoel. Jammer jy was nie daar toe ek en Misguide die swimbait trace gemaak het met die bleeding wire nie. Dit het rerig goed uitgekom.
@Kumz, were is the pic of the swimbait trace?
Hooch
Thanx a mill bud, thats my pride right there................ Moz here i come................Mr Zambo, watch out im ready:wfish
Kumz
Hooch ..That is an amazing trace ..If i may make a suggestion ...
If possible try & make 1 trace quiet similar to that but with 300lb carbon coated steel ... & remove about 300mm of carbon coating from hook end upwards - towards swivel ...
Just in case there is beeg Nunu there !!!
Another pic !!!
Hooch
Another pic !!!
Kumz, you recon a big nunu will bite threw 7 strand stainless steel wire coated with plastic? That is what the 210lb bleeding wire is made off.
Kumz
Yep .... personally i wud like to have a trace of that size just in case !!!
Pls also carry Skewer sticks for some of yr throw baits !!!
Use the skewer to keep bait straight ... u love to throw a Makkie !!!
misguide
definitely!
I use 400lb 49 strand wire on my swim traces.
you can use the traces as you have made but you may get bitten off.
you will also want to use a 2.0 - 2.5mm wind-on leader for the swim trace - the total of the leader and trace to 9m (6m leader and 3m trace on mine)
