Shannon wrote:
Monster wrote:
They why don't you just use sand
Because it doesn't turn clear
. And why do baits in the shop have massive stickers on them reading "Salt Inpregnated"
To tell you they sink
. I agree with the fact that it makes the baits more dence and that it is used as a filler material so you use less expensive plasticene
Plastisol, Salt actually makes the bait more brittle and makes it tear easier.
. But that is not the only reason
Look salt certainly doesn't harm the taste, but it is not used for that reason. A bait without salt is more flexible and last longer than one with salt.
I take it the salt doesn't bond with the plasticene. It could be the reason why the baits break and tear easily. So if the reason for using salt is to make the bait sink but also breaks up the structure leaving the bait weak why not use something more dense so less can be used leaving the bait stronger. I asked about sand as Sand has a crystal density of 2,7 and salt 2.16. So 25% less sand can be used than salt with the same sink rate. Settling can be minimized by using angular pieces of glass( sand and glass hve almost the same density both are made of mostly Silica glass has some zirconuim too), this increases the viscosity of the material decreasing the settling rate of the material.
The only way in which one material is compleatly invisible in another is if they have the same basic molecular composition. Organic materials look clear in organic solutions. Why glass is clear in water and diamonds are not. And that they have almost the same density, why flourocarbon is invisible. We know plasticene does not bond to salt and it will not bond to glass( so nothing gained nothing lost). Salt and plasticene have diffrent densities or you would not need to add salt to make it sink, same for glass but you can use less.
Im not saying that I dis agree with your point only that there should be better ways of doing things. I didn't state my points as the only fact out there only as a point of discussion so we can all learn from someone with obviously more experience.
A proper Senko is a perfect example, generally a proper Yamamoto Senko will last 1 fish. It's because they are so heavily loaded with salt to get the sink rate high and then a lot of softener is added to keep it's soft feel.
Have a read around on tackleunderground a bit where most of the hand pour lure companies hang out and make some of your own baits before you argue a point.
Salt impregnated baits are advertised for taste and not for sink rate or it would have said "fast sinking on the pack". Rather try and explain a point and help a couple of guys than to make things personal. Your last line was not positive and meant to upgrade yourself by demeaning others. That is not the culture of this site.
I've been trying for years now, the only place I got and get from is from accross the big blue. Online orders and then some weeks for shipping not too mention the $$$$$ you're going to spend, Africa is, well Africa!!
