Hi Reef,The Kingfisher pro braid was being used by the ESA guys in the beginning, but apparently after losing a few too many fish thro' breakups, they changed to Whiplash. I use the Sufix pro on mine, which has been reliable up til now, but then I've never landed a big bus...
That's what I'm currently using on my Saltist 50, was looking for cheaper braid for my SL50 as backing.Hi Guys
By all accounts, Berkley Whiplash PRO is probably the best braid around. If you can find it and can afford it, go with this braid (50lb test is 0.17mm diameter; 65lb test is 0.21mm diameter, if I remember correctly) - amazing stuff! Remember, it will last years and years (if you don't get spooled by a Bus!).
I have not used Sufix, but have heard good things about it. Power Pro has had mixed reviews ...
If I were you I would forget about the Kingfisher braid ...
The best way to join braid is to use two bimini's, one on the topshopt, one on the braid (not sure how to tie a bimmini using braid, braid isn't supposed to stretch) and join them using a cats paw.Guys i here yol'
I just recently put Pro Kingfisher braid on my 50. I used the bimni twist to join the braid to main line. Will this knot hold out ?
tp::
