HennieB wrote:
Thanks appreciate the reply. Reason I asked about lure vs fly is because I'm clueless with a fly rod.
I was also clueless before the trip having only had 2 prior outings to Dullstroom for trout and had never Czech nymphed or targeted yellows on fly. The beauty with Czech nymphing is that its a really simple technique and doesn't really require any fly casting. The guides were also really helpful and spent the 1st hour with us showing the technique without touching their rods to make sure that we were doing it right. I had my 1st hookup within my 1st 10 drifts ever and went on to catch about 40 yellows on my very 1st day.
After having lunch on day 1, I decided to throw a few lures (hornets) and managed to get 1 SM yellow and 3 cats in an hour. Switched back to the fly rod and straight away started landing yellows and muddies again which is why I would definitely not go without fly.
The one drawback about fly is that fly gear is insanely expensive. However you can still do it on a budget and have fun. The following options
- Rent all the gear from them apart from flys. It was R600 last year for the entire duration so say R650 to R700.
- My one friend who is not really an avid fisherman apart from these annual trips bought a Stealth Procast combo rod,reel and floating line for around R1300.
- I gambled on me getting into it and decided to buy a Shimano Biocraft 6wt rod (R850), Biocraft 5/6 reel (R1100) and Rio floating line (R550). I didn't want to have to buy again if the fly bug bit, which it did. Didn't break the bank too badly.
- I enjoyed the Biocraft so much that I bought another set except with a 5wt rod this time and Airflo Velocity floating line (R300).
- Don't spend a lot of money on the fly line as you tie mono onto your fly line and nymph with the mono, the fly line almost acts more like a backing.
- Flys are around R8 each, you only really need 6 types and say 5 of each. So flys will cost you around R250 to R300
- Waterproof Fly box R200
- Mesh vest R400
At the end of the day, I don't think I would of caught any more or any less fish with any one of the above options, so its really up to you.
Tight lines, Ant
