tkei wrote:
I am no expert myself but will add a question if I may. I slid a few baits this weekend int he kei (only one hookup and was reefed after about 30 sec). My question relates to the ESA bought slides. I used one I had made up myself and had no problem. my brother used an esa slide, and it just would not sluide doen the trace. I tried, he tried numerous times, no luck. it would run to just before the water and stick. It was an unweighted slide clip, would this have had an effect? His rod was a bit soft, would this have caused it. I was using my light tip on BM g3/ 4-6 and it was fine, but his was the old version of the g3- 4-6 (about 8yrs old).
How long must the sinker sit in the sand before you start sliding, as on previous tries, my sinker always broke free. annoying when you been shaking for a few min and then breaks free.
Tkei... it's been done before - to slide with a 6oz sinker, but you've really got to know what you're doing... it's really not the "recommended" way of doing things. A rod rated 4-6 oz is not going to stand up to the punishment of a 50kg+ inedible? You're taking a pop gun to a gunfight here.
A
soft tip rod will certainly prevent one from getting the slide out. The principle behind a slide being that their is an extremely tight connection from the sinker to the rod tip, on which the slide will simply 'slip' down. A soft tip rod will definitely casue slack in the line and the slide won't progress further.
The problem of your
sinker breaking free is because it's not heavy enough (I'm assuming you are using a 6oz and that you are using Wire grapnels?) A heavier sinker 8-10oz will sit vas after 5 minutes. But then you're not going to be able to cast an 8oz with a 6oz rod, right? The sinker should be sitting so tight that it's actually quite difficult to dislodge it - then you know you're ready to slide. Sometimes, the sinker is so tight, that it will actually break off before giving way...
The
unweighted slide clips nowdays are generally only used for a live bait. The weighted ones will certainly slide much more easily...
Recommendations: Up your tackle from light to Medium/medium heavy. As I said in the beginning, it would be practically impossible for someone trying this for the fisrt time to slide with a 4-6oz rod, using 6oz sinkers...
The other possibility might be that your mate put the slide on back to front.... if thats the case, t ain't going nowhere!
Hope this helps.
