help with rod joint rubber
one of those rubber plug of the tip got stuck in the mid sec
and puled inside
do you know how pull it out ?
should i take the opposite rubber out from the mid sec and push it out?
if so can i remove that rubber with heat and glue it later ?
thanks allot for any help
eyal
flippy
not sure what will work but thinking you stick a longish stiff wire with a hook at the bottom end and try force it between the plug and rod blank
keep it flat against the blank so you can get it past the plug and if you get it past turn it around so hook can be against plug and try pull it out.. this first instead of removing the plug from the mid section
Try this method but give it a good shot of silicone spray, which is a lubricant that may facilitate removal.
Good luck.
Capetonian
COBIA777
I would not apply any heat near any graphite. I would try this. Get hold of a susati stick , sandpaper a flat edge on it , apply a touch of super glue to the flat end of the stick, insert the stick VERY carefully into the rod where the ruber stopper is stick it to the stopper wait till nicely stuck and manouver it out slowly, repeat if necessary.
Hope it works?
Leave it where it is.
It is a cosmetic and not functional part.
Digging around could and probably would lead to damage to the blank.
howsit flipy
thanks for the quick replay
managed to fix it today by pushing an old carbon stick in to the mid sec,pushing both tow rubbers out backward (the sec is cones )
stick back with epocsey glue
should i use some other glue like-rubber seal locktite or sikaflex ?
thanks capetonian did used silycon spray
thanks enigma i wanted it out cause i"m using both 2 tips of that rod
thanks allot _seal1__seal1_
eyal
