help with light setup
therado
looking for a light setup to mess around with in the shallows while the exage is in the rod holder.
the problem is my budget is about R500.
any recommendations?
Thanks!
Inky Squid
Active member
Get yourself a 9ft rod and a size 4000 grinder, loaded with braid (only 100m and nylon for backing = cheaper). Past few weeks I got the following on my exact setup:
5x cob, biggest 6.5kg
1x cracker 8kg
Loads of elf
Killer outfit, cast up to 60m.
Speedmaster
I bought a nice 10ft Loomis rod from Russel in Parrow. It is a 3piece. Very nice rod. With a Daiwa crossfire 4500 reel. Setup cost about R650. Very leka setup.
Francois13
if you go for a 4000 size reel, shitmano is the best way to go (value for money)
rod and line is your choice!
Inky Squid
Active member
Agreed Francois, that Sienna is a killer!
If your budget was R800.....
Reel: Shimano Sienna 4000
Rod: Daiwa Megaforce 9ft heavy
150m 20lb Casting braid.
.30 backing.
therado
shot for the advice guys,
think i could push for the 650 outfit.
although what do u think of this as my first choice under budget
Daiwa SweepFire X Series Model SW 4000X reel - R198.00
Daiwa Megaforce-B Spinning Rod MFB 802MFS - 8ft - R244.00
R 442 - not sure about shipping cost.
roland
Hi therado.
Safe your R500 for a rod. I'll sponsor u a reel if u want it. Its a rovex duren. Have some suffix 20lb braid on. I'm sure the reel will be ok for wat u want to do.
Speedmaster
If you maybe can get the Sianna for that price. I would rather go for it. I do not personnaly know the reel, but I love Shimano. I think a 8ft rod is a bit to short.
roland
Hi therado
Keep your R500 for a lekker rod. I have a reel for u. If u want it. Then when you have R500 again get yourself somethinh else if needs be.
Its a rovex silun 3000. Have some 20lb suffix braid on. U can have it. I'm sure it will do the job u have in line for it
roland
Hi therado
roland
Hi therado
roland
Its basically similar in size to my shimano solstace4000. So I would go for 8-9ft. Have a look at the loomis 8 or 9ft or the shimano vengeance 8ft. Daiwa megaforce is also a solid rod. 9ft. Perfect rods to scratch gullies with and well within your budget.
Oh and I think its 15lb braid. Can't remember
roland
I have one condition tho.
1st catch with it must feature a lekker report with the reel next to the fish. !!!
