[color=#006600]Xt660x[/color] wrote:
Had my first cast with the 50 over the weekend.....boy what a sweat reel! I need to ad that doing the "sinker drop" (for a better word) test before casting seemed to have saved me from any major over-winds.
Had a few close calls though, but placing tape below 100m of line on the spool made the slight winds a pleasure to undo - considering that it was my own fault for not keeping my eye on the "touch down"
Say Def..............did you ever find out why your line was breaking?
Yes. . If you go and read my post n casting sl 30 vs Sl 50- you'll see I learnt a HELL of a lot from the guys on the frum .
Basically It's simple . a case of where the Line was too thick on the 30. The reel spools up twice as fast as a 50 , then the line needs to come off at one hell of a speed- which it cant do . so you cast , the line and spool spool up - and the spool goes into overdrive - the sinker can retrieve line off fast enough unless its like 6 or 7 ounces -and even that is not really going to keep up- and - 30Meters into your cast- cheers china , go buy another grapnel .....................
So I changed from .50 to .40 mm Line . I used a 4 oz "dollar" or spoon sinker- the plain jobs man , installed the centrifugal brakes on the inside of the reel - and 660- you will Never believe it's the same guy throwing with the same reel .
I smacked 125 M the other night , from not using the reel (NEW) for over a year . Casting only with my 50 .
It was just there that i realized , Line is not something you go ask Mommy to pick up from the store-she'll buy you 15.9 , or 18 kg
And the reason we bewen doin that was simply because we were too lazy to mos fit a Leader line , and use line that suits the reel - Not just what some twit at a shop sells you or tells you to buy . thinner line also means less drasg through the air - more distance , less drag in the water - lighter sinkers .
I tell you man , I have learnt So much it's not funny . I did manage to throw one MOTHEr of a kraainess on Monday - My first EVER - the other Images were of other guys casting with my Reels .
I simply used a heavier sinker , 1 oz heavier - and presto . From sunday not being able to cast the 50 (?) to going back to 112 Paces .That infamous touch-down on the water I couldnt see is what caused the Massive bob-marley . WIth the centrifigal brakes in place , correct line matched to the right sinker , is where the distance starts coming out ..
All in all - go and read my post . I with they'd sticky it to the top . A lot of people can learn through all the info and trial and error I got from that post .
Cheers .
