Help needed Nautical Charts
fedu
In two weeks time I'll be going for a long weekend in a southern Angolan Province, Namibe.
I've been there a couple of times mainly bottom fishing and trolling.
My main problem there is location of potential good spots for jigging/bottom Fishing.
My target there will mainly be Grouper (Yellowbelly rockcod mainly), Amberjacks and snappers.
My jigging experience tells me that very good spots for jigging usually start at 60 meters deep, I would not like to jig above 150 meters deep.
With that in mind, and looking at the following nautical charts, what would be the places you guys would try first ?
The depths are in metric system.
First target area:
fedu
PDF version of the nautical charts for better reading.
  • nautical pdf.pdf
ignatius
Fedu, I found a guy who apparently did commercial fishing in that area, also a bit south, at a place called Santa Grossa,the lighthouse north of Bentiaba. Presently he is living in Swakopmund.
Should we have a member in Swakop or Walvis who are willing to collect the info then he can PM me for datails of this person and maybe find what you need.
Otherwise I shall see what I can find out by telephone. Just give me acouple of days.
fedu
Thanks Ignatius, I'll wait.
Up until now I've managed to talk 2 years ago with an old guy that used to fish this first area in the 60's, and he told me to look NW of Carunjamba point for a big peak around the 90 meters where they would catch what he called "peixe grosso" translated "very large fish".
I'm thinking on doing this area marked as A because of the potential dropoffs from 50 to 500 meters, but the chart says it's Sandy bottom what usually is not a good sign.
fedu
The other area that on the second nautical chart I think might be intersting exploring is this one marked as B.
Rocky bottom with potential dropoffs from 30 to 300 meters.
Both these areas are very near shore. The continental shelf there is very short.
I'm not used to these "virgin" territory loking for fish, I'm usually able to get some references from local fisherman and pick up from that.
The problem here is that the local guys don't fish anymore (at least nothing deeper than 30 meters) and the old fisherman have died allready.
fedu
A nice side story I found on my research of Carujamba area is the following text by the Portuguese Hydrographic Engineer Alexandre Magno de Castilho, published in 1866 in his description of Arican Ocidental coast.
"Da banda do N. do rio Carumjamba cresce um viçoso mangal, e pouco para S. se ergue uma barreira avermelhada, talhada a pique e mais alta que a terra vizinha; pode-se fundear 2 milhas para O. d'essa barreira, em em 50 metros de fundo, e 2 a 3 milhas ao 04NO. magnetico d'ella de encontra muito pescado."
Basically what he wrote was that the area NorWest of Carunjamba 3 miles after the 50 meter depth  was incredibly rich in fish, if you look at it, it's the area I've marked as A.
fedu
Klipdrift wrote:
The big drop off just in front Santa Marta, NE off your spot also looks good.
Thanks, Klipdrift.
I think you are talking about this area, I've allready fished this "rocky" area C, lot's of yellowbelly rockcod but small, at the time I had no nautical chart of the place.
The inside bay area is well charted, I've not post it before because local fisherman fish it, they get many fish, but probably because of that, mostly small, from time to time they get a fish between 20 to 30Kg.
For Diving is a great area, I've seen divers there with impressive catches, some years ago I've dived there, nice place but I didn't like having the sharks looking at me all the day :)
The problem there is that fish is so abundant that they don't even bother to go after the bigones they stay very near shore up to 30 meters depth and without worries, or too much work, the local fisherman make their living.
In the 60's the commercials used to fish it properly, hand line, bigger depths, bigger fish "peixe grosso" but since 75 most of the popullation went away and now they don't even bother.
fedu
tackle whore wrote:
dont forget the 2000m contour :hyst::hyst:710g full lumo !!!!
The same for you, and on top of that I hope when you come to the northern fisheries you have to deal with one of these "little" guys, in, lets see..... 200 meters deep!!::S::S
ignatius
fedu, please stop posting these photos, you freak me out.
What is the avg size of the small fish.
What is your target weight, when you see 20-30kg fish as youngsters.
I hope tackle whore saw the pic, seems to me he disappeared, maybe he is moulding a cast for those 710g full lumo.::tight:
fedu
Sorry ignatius,
That's an old photo 1971 from the NORTH fisheries (a fishing competition in Ambrizete), Pargo heard about a 90Kg Grouper this year, and it's regular to hear about 40 to 60 kg snapper there (up North), it was a joke for Tackle, because a fish that size would break is back :)
In the SOUTH I would be very happy with regularly getting fish above 10 Kg, and from time to time a +30Kg,  my usuall average is bellow this :)
P.S. - Made some progress in the spot research, used Google Earth to identify potential spots, will post the "logic" behind it to see if anyone can give me some feedback about it (at least a forget about it I've tryed that and didn't work :) )
fedu
Try to look for "visible" changes in bottom, and this are the "fishable depths" result.
As a test I used the same logic on Luanda and then checked the results with my Luanda fishing spots, and they all were on target or near some spots I allready fish with good results.
Let's hope the same thing happens with Lucira.
fedu
Just drove 800 Km back to Luanda but wanted to tell you guys that the research worked.
Yesterday 2 oclock in the afternoon, 105 meters deep, weighted 33Kg.
Thanks for all the help, will post report later.
ignatius
fedu
You have done it again. I was waiting for your post, and now I have to wait for the report. I am glad you had a safe journey.:wfish
