Took the boat out to Harties yesterday and launched from Ifafi Aquatic Club. At the gate we had to present our COC & COF paperwork before being granted entry (first time this has happened to me, so well done to them). Once we were on the water I cruised past Meerhof toward the train bridge, it was the first time I had done this and checked out the area with the fishfinder. I had bank fished this area with great success for many years and I was surprised to learn the following and thought I should share this with you:
Meerhof: The depth of the water between the concrete blocks is a mere 2.1 meters. I was always under the impression that the water here was a lot deeper. There are no drop offs at all. In fact the entire area is flat, most probably from all the soil that has been washed down from the river over the years. Approximately 10 meters past the nearest concrete block towards the fishing area directly in front of Meerhof the depth is a mere 1 meter. In this area there are numerous sand banks as well. I did not venture all over the area as there were anglers on the bank and respected their presence. To the right of the fishing area between the dead trees the water is only 800mm deep.
Oberon: The area close to the train bridge is also 2 meters deep. There are a lot of sand banks in this area. The river was flowing fairly strong into the dam making fishing on the Oberon banks almost impossible because of all the rubbish and debris that seem to collect against its banks (explains why its banks are always so filthy). The rubbish and debris covers an area of approximately 100 meters wide that flows around and hugs the banks of the entire fishing area.
The water was slightly discoloured but we saw no green Algae anywhere. The water temp was only 23 degrees (most probably because of all the rainwater). A LOT of BIG fish were continuously jumping out the water all around us.
