Handle for shimi 15/30
Mouldz
I know I sound like a "cheap skate" but my shim15/30 handle broke,I work in a plumbing shop and I was looking at a Stella tap handle and how comfortable it looks,so viola my reel has a shiny new handle,these are chrome plated, solid brass so I think it will last,I was amazed that the sleeve and shaft fitted so well::tclaph::tclaph
old salt
Hi bud
A tap handle sounds good but could land you in hot water too.:SSS
Just a tip be cautious when fitting after market power handles to any reel, IE. gears are made to handle a certain amount of torque and when you increase this it wil imapct on the drivetrain for certain. :fbash
More strain is added on the gearbox and bearings the support it as well as the reel cage and anti-reverse system of the reel.^^..
Then another IMPORTANT thing NEVBER add any weight to your reel rather take off also never add any weight in the form of a heavier handle on a graphite rel especially it will detract from fishing pleasure and balanc eof your outfit more than you initailly realise.:fbash::S:fswim
There are powerhandles with very simular throw to the standard handles so torque differences is not that great hence the reel works within boundary set for it.
My advice get a stock handle or the Gwave power one its not counter balanced but the throw is close enough and then offcourse the gearing and dog on the 15-30 can handle MUCH more that most folks realise.:SSS
Food for thought. ALWAYS try to fish lighter than heavier it increases the fishing pleasure.
Regards
Jonathan
